Rack operated tailstock ?
Home › Forums › Manual machine tools › Rack operated tailstock ?
  • #451049
    lfoggy
      @lfoggy
      I am considering fitting a rack operated tailstock attachment to my Myford 254+ to help with drilling and reaming etc. For these applications the ability to rapidly move the tailstock barrel would be handy for clearing chips and the extra sensitivity of the rack mechanism should add feel to drilling as well. I am wondering how good the rack operated tailstock is for other applications however, like pressing a revolving centre into a work piece.
      How convenient do users of this type of tailstock find them? Is it a worthwhile mod?
      #13772
      lfoggy
        @lfoggy
        #451067
        Robert Butler
          @robertbutler92161
          The use of a Rack operated or lever feed tailstock is very convenient for most operations.
          Robert Butler
          #451071
            Posted by lfoggy on 07/02/2020 12:55:06:
            I am considering fitting a rack operated tailstock attachment to my Myford 254+ to help with drilling and reaming etc. […]
            It becomes a two-handed operation [or some variation on that theme] … but I think the benefits outweigh that small disadvantage.
            Phil P
              @philp
              I use a standard screw feed tailstock 95% of the time on my Myford S7.
              I also have a spare ML7 tailstock fitted with a Cowells rack feed attachment, I fit and use that instead when threading with a die head.
              Phil
              #451080
              Alan Jackson
                @alanjackson47790
                I can apply more than enough force at the lathe centre with only relatively light single handed force at the rack handles with either my smaller handle Stepperhead rack or my longer levered Chipmaster rack. Much better generally than a screw feed, and much better for drilling and removing the drill for chip clearance. Look in my albums.
                Alan
                Edited By Alan Jackson on 07/02/2020 15:27:16
                #451134
                Meunier
                  @meunier
                  Having had a Cowells Capstan rack-feed tailstock on the ML7 for many years, along with @CornishJack, I can compare it with the usual screw-feed tailstock and say that it is much better overall – more sensitive more instinctive and quicker in operation.
                  With a 1.6mm drill in the tailstock chuck and a 3mm bar of stainless in the 3-jaw it is possible to 'peck' and withdraw to clear chips with just a finger and thumb on one of the capstan bars with hardly any effort, to a depth of 12mm..
                  Highly recommend.
                  DaveD
                  #451141
                  Phil P
                    @philp
                    For anyone wondering what the Cowells capstan rack feed tailstock looks like, this is mine.
                    It took a long time to find one at an affordable price, I dont think they have been made for a lot of years now. There is one on ebay right now for just a tad under £300 !!!
                    I have added the stop collar at the rear end so it halts the spindle and trips the die head open at the correct depth.
                    Phil
                    Edited By Phil P on 07/02/2020 19:56:37
                    Edited By Phil P on 07/02/2020 19:58:24
                    Edited By Phil P on 07/02/2020 19:58:58
                    #451151
                    Meunier
                      @meunier
                      Posted by Phil P on 07/02/2020 19:55:23:
                      Mine is the same but in Grey. In 1973 was fortunate to purchase the 1965/1966 year ML7BT with Brook Gryphon 2speed motor and Dewhurst control gear, with the Cowells tailstock and Trileva and QCGB already installed, with many chucks+dividing head, etc from a fellow club member retiring from workshop activities.
                      It took some persuasion for the budget manager to approve £327 but it has earned its keep many times over.
                      Back on topic, I deduce the Cowells was installed between 1965/1966 and 1973
                      DaveD
                      Edited By Meunier on 07/02/2020 20:42:39
                      #451152
                      lfoggy
                        @lfoggy
                        Thanks Phil P,
                        That looks very similer to the Myford rack operated tailstock attachement currently available on the Myford website…and I agree, not cheap for what it is.
                        #451248
                        ega
                          @ega
                          Posted by Michael Gilligan on 07/02/2020 14:35:37:
                          MichaelG:
                          May I trouble you to elaborate your two-handed point? I'm having difficulty in envisaging a situation in which there would be more of a need for two hands with the rack feed as opposed to the screw.
                          I use a lever feed with great satisfaction on my S7 and can't imagine reverting to the standard arrangement. The only small disadvantage that I encounter is that the tailstock is somewhat tail-heavy when the lever is fully extended to the right. Incidentally, although I would like to try the (expensive) rack feed, the lever does allow you to vary the mechanical advantage.
                          #451255
                          John Baron
                            @johnbaron31275
                            Hi Guys,
                            In the old days, a capstan tailstock feed was about all you saw. Particularly with the ability to have six different tools immediately to hand.
                            #451260
                              Posted by ega on 08/02/2020 12:31:46:
                              MichaelG:
                              May I trouble you to elaborate your two-handed point? […]
                              Yes of course …
                              The comment was specific to the use-case of appropriately loading a centre
                              The rack & pinion doesn’t hold position [pressure] and therefore to lock the barrel I use my other hand
                              … other body parts are available.
                              ega
                                @ega
                                Posted by Michael Gilligan on 08/02/2020 14:29:48:
                                MichaelG:
                                Yes of course …
                                Ah yes, of course; I should have thought of that.
                                But wouldn't you lock the barrel with screw feed?
                                #451262
                                  Posted by ega on 08/02/2020 14:54:07:
                                  Yes, but it holds position better than the rack, so you typically have the option of using one hand to do the two jobs sequentially.
                                  [very dominantly right-handed, so I tend to notice these things]
                                  #451347
                                  ega
                                    @ega
                                    Posted by Michael Gilligan on 08/02/2020 15:08:18:
                                    Thanks for explaining.
