qualos junior lathe
qualos junior lathe
Home Forums General Questions qualos junior lathe
  • #155983
    kevin barron
      @kevinbarron12390
      ihave a qualos junior australian made circa 1940 lathe without changegears and would like to cut new ones i have little experience and would be interested in any imformation at all regards dp etc for correct cutters and any info at all regarding said lathe very keen newcommer from oz
      kevin barron
        @kevinbarron12390
        changegears
        #156014
        John McNamara
          @johnmcnamara74883
          The Qualos is similar to but not a copy of the south bend bench lathe
          They were well built.
          Or
          One lives across the street from me at a friends house, unfortunately without change gears.
          Bazyle
            @bazyle
            Boxford gears are 18 DP and Myford are 20. Hercus was another SB copy in Oz. The centre hole might be more important and  I dont know that off the top of my head.
            Edited By Bazyle on 22/06/2014 17:27:36
            #156052
            Ady1
              @ady1
              Find the centre hole size and buy a set for a different lathe with the same holesize from xxxxbay etc?
              #156057
              Pat Wright 1
                @patwright1
                Hi Kevin,
                I have a Qualos Junior purchased about 30 years ago which was my learning curve, gave it little real use and now unused for last 10 years when replaced with a Taiwanese TY 11 X 24B.
                The Qualos has a complete set of 11 screwcutting gears, unused by me, are in excellent condition except for one that has about two thirds of a tooth broken off. They are made of black bakelite (or something similar) and branded Qualos.
                I have no idea what the DP is, but have measured the overall dia. of three which may be of help:
                20 tooth 1.832" dia. give or take 2 or 3 thou. as readings vary but I have quoted torwards the higher end of all readings.
                40 tooth 3.490" dia.
                60 tooth 5.160" dia.
                Just in case you ask I would not sell the gears separately from the lathe.
                Pat
                Hamilton, New Zealand
                p.s. Tomorrow I will get professional advice as to DP and post it here.
                #156125
                Pat Wright 1
                  @patwright1
                  Kevin
                  Went to a local CNC engineering shop and they measured with a gauge and said it was 12 DP.
                  Pat
                  #156132
                  Roderick Jenkins
                    @roderickjenkins93242
                    Pat,
                    To get the DP, just add 2 to the tooth count and divide by the outside diameter of the gear. So, 42 divided by 3.49 is 12.
                    Cheers,
                    Rod
                    #156204
                    Pat Wright 1
                      @patwright1
                      Rod,
                      That's a dandy little formula but maybe too complex for the CNC place I went to as they poked around in a cupboard and pulled out a tooth gauge just like and overgrown thread gauge!
                      Thanks Rod,
                      Pat
                      #174187
                      Alfred Rofe
                        @alfredrofe91484
                        I have a Qualos Junior Lathe however it came with out an instruction book does anyone have a copy they may email or send me. Alfred.
                        E-mail removed, contact by PM if you can help
                        Edited By JasonB on 01/01/2015 07:49:05
