Hi. This year I hope to purchase a lathe. If I do, I'll need a lathe with a chuck that can accept work of at least 45mm in diameter. So, I'm looking at products available. Now, obviously I'm concerned that the lathe can take bar up to at least 45mm in diameter. Here is the specification given for a popular lathe:
Motor – 300W/230V
Distance between centres – 300mm
Swing over bed – 180mm
Spindle Taper – MT3
Spindle Bore – 20mm
Tailstock Taper – MT2
Spindle Speeds (Variable) – 100-2500 rpm
Imperial Thread- 18pcs – 12-104tpi
Dimensions – 820 x 295 x 300mm
weight 45kg
There is a link which is supposed to give "info on this machine" If this worked maybe I would not be making this post.
Anyway, no mention of the size of work the lathe can handle with the supplied chuck.
Also, looking for a possibly larger chuck, I've spotted a 4 jaw chuck on a different site. Apart from the description "4 Jaw Independent Chuck" I'm given the weight as 5Kg. Although I can contact someone by way of messaging.Discovering the capacity of the chuck is not proving to be a matter of reading a specification. Seems odd that. Rich
