Hi Guys well a lot been happening lately after so many problems.
Decided to rebuild the engine as having to many problems thought it would be far better.
With the Help of our Rugely club members who have been amazing.
Found problem with valve gear pin damaged then water feed pipe was to small for automatic water feed.
Spring had gone on oil pump so was not working.
on top of that made a new screw regulator tried to keep old cheese type regulator but could not get to seal.
Of the engine you could blow through perfect but every time when fitted it leaked.
In the end a tool maker from our club took it with him and made the screw type to try.
The train in the meantime has had a repaint new running boards.
With the already added blow down valve water gauge new pipe through boiler for blow down valve.
plus new pipes all brazed glands all repacked and refitted.
Whilst boiler was of they gave it a new boiler certificate after pumping to 160 psi.
Just waiting for the parts to come back and then get on with refitting and hopefully a steam test.
When i finally get my steam test will post a pic for you to see
