Original Myford raiser block queries
Home › Forums › Beginners questions › Original Myford raiser block queries
  • #274928
    KWIL
      @kwil
      Per Myford Catalogue No. 775.
      Part No. 20/025 Raising block with jack screws and securing screw………..pair £54.34
      #274936
        Well … I hope the OP has 'got it' … because I, for one, am lost.
        One simple question: Are the blocks tapped with two different sized threads ?
        David says No … one thread for the levelling screw, and a plain bore
        KWIL says Yes … one thread for the levelling screw, and 5/16" BSF for the stud.
        This might be important [depending on the chosen method of removal of the 'stuck' studs.
        P.S. I have selected the least confusing [to me] names for the components, and assumed that 5/15 should read 5/16 … I hope this causes no offence to either or both of the combatants.
        #274954
        David Standing 1
          @davidstanding1
          Posted by KWIL on 01/01/2017 19:06:02:
          It does not have to for you, the OP has said he has got the hang of it and is going to have a go. fist
          Well, Happy New Year to you too surprise.
          Have i done something I am unaware of to upset you? sad.
          #274974
          choochoo_baloo
            @choochoo_baloo
            Thanks to David's double nut trick, I have successfully removed all 4 studs.
            To answer the £1,000,000 question: there are indeed TWO female threads, separated with a shoulder, in each block: 5/16" & 9/16" BSFs. The stud does thread into the block, but mine was definitely gunked up and took some leverage to remove.
            Thanks all again for the input.
            Edited By choochoo_baloo on 02/01/2017 00:32:05
            #274979
              Posted by choochoo_baloo on 02/01/2017 00:31:26:
              Many thanks for clarifying that yes
