The whole wind/solar idea seemed great on paper to the uninitiated but is in reality an uncontrollable monster. I have observed several big wind turbine farms all idle during the hot sunny spell we have been having, at least you can feather the blades ! Tidal is at least largely predictable ! Noel.
The whole lot is fully controllable. No doubt about that, so absolutely nothing to do with the technology!
Wind turbines can be turned off – not by feathering the blades but by turning the rotor away from the wind direction. Feathering the blades is simply a means to maximise the power delivered, by the turbine, as they are designed to rotate at a set, controlled speed. This can occur when the wind speed is too high for the safety of the structure. All turbines turn away from the wind to avoid over-speeding.
It is different than constraint. Constraint occurs simply where the grid cannot absorb the power, or the grid would not be able to absorb/deliver all the available instantaneous power (the grid cannot store electricity, it can only transmit it from source to user).
The grid sometimes cannot transmit the power because it was built as a radial system from fossil power stations and the less ‘robust’ parts are at the extremities. Off-shore wind turbine power comes ashore where the transmission grid may not yet be reinforced – hence the off-shore generation must be constrained.
The contract to get that large investment (for the installation of large numbers of turbines required, the government, at the time, guaranteed that they would be paid compensation if the grid was not reinforced in time. Clearly it has not been reinforced adequately by the National Grid and paying curtailment payments is far cheaper than the turbines never having been installed in the first place (they would still be burning dirty, expensive coal and gas instead of renewable energy from the wind).
The other end of the scale is when there is too much generation – either it is used or lost by turning off turbines or switching off solar generation. Switching off solar panels is simple – one can easily flip your switch at home, to stop your installed solar panel generation.
It is at these times when any surplus is sold cheaply to anyone who can ‘turn up their wick’. The generation system is such that at times the price becomes negative.
The problem is that the grid still relies on gas generators for a ‘black start’ if there were to be a power outage. It’s called ‘spinning reserve’ – steam driven generators are still needed for this stand-by duty at the present time, so they have to be kept turning, even if making little generated power – hence there is always (yet awhile) a couple of Gigawatts of gas-fired generation.
The National Grid are working towards being able to restart the grid (after a black-out) by other means. Black-outs are necessary when there is, for some reason, insufficient generation due to an unexpected failure within the whole grid. It could be a local power outage (relatively easy to sort out) or might cascade into a major system shut-down. The National Grid has statuary responsibility to maintain both voltage and frequency of the supply within tight limits.
The grid can easily turn off a generator if there is too much power, but not enough is another story! Turning off any generator (they all have at least half hour contracts to honour) costs money. We only hear about wind constraints as they have been in the news for years.
Hope that lot helps to explain some of the misapprehensions circulating. I’m no expert on the subject and ‘‘contracts for difference’’are yet another set of ‘juggling balls’ for the system to cope with.
Let’s be clear, there is no madness, whatsoever, involved with Octopus Energy, so I still stand by my original post. Just someone trying to make a mountain out of a molehill, IMO.
As for time-of-use pricing, that has been going on for decades. E7 for domestic users and power agreements for industry (night time power was far cheaper because coal-fired generators could not easily reduce output while maintaining efficiency).
Power costs could include not only time of day/night rates but also reducing usage for up to two hours at a time with (I think) only one or two hours notice when requested by the grid. I can’t remember exactly how much power I had to shut down at these maximum demand periods (2-5GW was likely) and we regularly used 10GW (or more) during the cheap night rate period compared to the day rate.
