Nice job Russell, looks magnificent ! I kept my steel plated m/cycle bits well waxed. The bike was only taken out in good weather so didn't experience your " it is not weather resistant unless you plate with copper first."
It'd be interesting to read about how you did the plating.
The topic was discussed on here before – just over a year ago.
I've tried b4 to insert a link back to postings without success, so trying again…..
Forgive the repeat, but to anyone "contemplating plating" at home, this was my posting then (truncated):-
"…. kit was 'Dynic Sales' (no longer exist)…….But – and it was a big but – you had also to purchase:-
An aquarium heater / aquarium aerator / amp meter / stabilised power supply or 12v battery / accurate current controller as well as being prepared to construct various non ferrous rods from which to suspend anode & cathode on top of a plastic container. Effective plating required control of temperature, current, agitation and a perfectly smooth surface on the steel item otherwise corrosion pitting would show up badly after plating.Eventually results were consistently good. (I did a petrol tank filler cap, shrouds for rear shocks, lamp bezels, Cu oil pipes and numerous steel bolts and nuts).
Bottom line? It is possible to Ni plate at home but requires one hell of a lot of aggravation and preparation."
(Edit for typo)
Edited By Fowlers Fury on 18/05/2019 11:35:38
