Newbie with Soba parting tool question
Home › Forums › Beginners questions › Newbie with Soba parting tool question
  • #91457
    MattK
      @mattk47317
      Hi,
      This is my first post on here. I have a Myford S7 Mk1 which I have been playing with for a few months. I have already got some great advice from this site but I have hopefully a simple question.
      I recently bought a clamp type parting tool from Chronos that states it is compatible with a Myford like this one **LINK**
      I can't get the cutting edge to centre height. I have a dixon type toolpost and it sits maybe 2mm too high in the lowest position. Also in a (non genuine) rear toolpost it is in the wrong position. Has anyone got one of these and experienced similar issues? TIA
      Matt
      #6166
      MattK
        @mattk47317
        #91459
        Francis Sykes
          @francissykes95134
          I have a similar parting tool – just bought from RDG.
          It has a 9mm shank – and I had to make some packing to get the centre height correct – I have a home made single toolpost arrangement that merely clamps the tool to the compound slide. I just milled off some 3mm aluminium to make it the correct height.
          I guess that doesn't help you too much, if you need it lower then perhaps mill off 2mm off the bottom of the shank?
          #91460
          David Littlewood
            @davidlittlewood51847
            Matt,
            Can't help you on that specific tool I'm afraid. For many years I struggled with parting tools of that general type – they worked, but it was always a slightly nerve-racking experience with steel of any size. Then I bought one of these **LINK** and it was a revelation, an order of magnitude better than any other I have tried. It works well because it curls the swarf into a shape narrower than the groove being made. I bought it after seeing a demo at the Myford factory of someone parting off under power feed at a non-backgear medium speed; magic! Treat yourself.
            Oh, and I can confirm that it fits in my Dickson toolholder system (on a S7) with no problems.
            David
            #91469
            Chris Trice
              @christrice43267
              I've got that exact same one as David and can vouch that it's probably the best type out there too.
              #91471
              blowlamp
                @blowlamp
                The Greenwood Tools parting system is good, as is the one from JB Tools and I find them roughly equal in their capabilities. However, the cost of the inserts from Greenwood Tools is high in my opinion, so I source from either JB Tools or from here
                Martin.
                #91524
                MattK
                  @mattk47317
                  Thanks for the recommendation for the parting tool. David, I take it from your post that you part off from the front then? I have quite a long list of bits I still need to get but I have stuck this one on my list and will take a mil or so off the shank as suggested to see if I can get it to fit in the meantime. My main issue was it is advertised as suitable for the Myford but I can't see how it would fit.
                  I also have a short bit of HSS I got already ground that my uncle gave me and I have had good results from the rear toolpost but it is quite short and can only part about 3/4". One thing I found was that it pays not to be timid, and seemed to work better when I kept the feed going rather than hesitating.
                  #91526
                  David Littlewood
                    Matt,
                    Yes, I use it mounted at the front; I never really subscribed to the rear toolpost thing. You are right not to hesitate; like all tools, they work best when actually cutting, and in fact letting them rub is a major cause of blunting the tool. I find dripping a little neat cutting oil every 10 seconds or so (for steel) is quite enough
                    David
