Posted by J BENNETT 1 on 17/01/2019 13:25:55:
Looking at a suppliers web site (Stakesy's) I notice that Femi produce a wide range of portable bandsaws, starting from £299. Clearly they have less features but are they equally as good at basic cutting as the more expensive models. Given the limited amount of cutting I do I could not justify the more expensive models but might consider one of the basic models.
From the research i did prior to purchase, yes they are all good. When i first came across Femi no one in the UK was selling them, you had to import yourself, so was pleased when Stakesy’s started to stock them. Decent prices too.
I think the only real difference with the cheaper models, aside from the obvious like smaller cut capacity and lack of auto downfeed, is the blade runs the conventional way. Not sure what the advantage of a reverse cutting action is, or if there is indeed any advantage, but the more expensive ones run like that.
One slight disadvantage of the reverse blade direction is you cant fit a vertical table, which is an option on at least one of the cheaper models.
Edited By Alan Waddington 2 on 17/01/2019 13:51:54
