Kwil,
Thank you sir. Lol NO banging !!
Used the vice and pressed them boogers right out.
At first I wasn't sure if just the center pushed out or the whole peg. I used a small 3/16 tool first and the center pushed in but the peg nor the outer head on the peg wasn't moving.
I then tried the whole piece and it pushed it right out.
My only question now is why do they have a pin in the peg. I actually pushed one of those center pins in about 1/8". Will that center piece being pushed in make any difference.
I think I see now that it is capping off the pocket for the grease. The grease hole is still clear in side of shaft so I didn't push it in beyond that hole so hoping it will be fine.
Thanks again,
Daniel
Edited By Daniel Place on 24/01/2014 15:18:06
