Myford ML7
Myford ML7
Home › Forums › Beginners questions › Myford ML7
  • #6126
    David Blight
      @davidblight39097
      Modification to saddle
      #90066
      David Blight
        @davidblight39097
        The saddle on my ML7 no. K77035 gets progressively tighter when moved towards the tailstock. Measurements across the front shear show large variations, measurements across the bed show less than 1 thou.
        Gaps between rear of rear shear and saddle were 18 and 20 thou.
        In ME vol 167 no. 3908, 1-14th Nov 1991 postbag page 501, J.B. Millar presents a solution for my problem which appears to be a very simple and hopefully within my capabilities.
        Have any fellow owners carried out this modification, and are there any snags?
        What method of restraining the new spacer is adopted, and what provision for oiling is necessary?
        David
        #90072
        nigel jones 5
          @nigeljones5
          mine is exactly the same – would like to know how to fix it??
          #90077
          mgnbuk
            @mgnbuk
            A method I have used sucessfully on my Super 7 was described in this thread
            http://www.model-engineer.co.uk/forums/postings.asp?th=64457
            HTH
            Nigel B.
            #90103
            David Blight
              @davidblight39097
              Thank you Nigel Barraclough for the reference, most helpful.
              Nigel J2, the site recommended will give all the information you need.
              David
              #90225
              nigel jones 5
                @nigeljones5
                Thanks. I read it. I didnt understand it.
                #90245
                Chris Trice
                  @christrice43267
                  Nigel, basically the early lathes used the outer and inner vertical surfaces of the front shear of the bed to guide the saddle assembly. Later lathes used the outer face of the front and rear shear leaving the inner surfaces of both shears exclusively to guide the tailstock. With the later lathes, because they use the outer surface of the rear shear to guide the saddle, the saddle is also wider at that point and therefore there is a larger area in contact with the shear and less prone to allowing the saddle to rotate off axis on the bed. The outer surface of the front shear nearest the operator is the surface the gib strip is adjusted against in both cases.
                  #90246
                  Chris Trice
                    @christrice43267
                    The article is how to convert the early saddle in such a way that it mimics the later saddle arrangement by making use of the unworn rear shear outer surface.
                    Edited By Chris Trice on 04/05/2012 23:04:20
