Myford ML7 Leadscrew
Home › Forums › Beginners questions › Myford ML7 Leadscrew
  • #280594
    Andrew Tinsley
      @andrewtinsley63637
      I may well be in need of a new lead screw for the above. Many years ago, there was a company that manufactured lead screws, does that or a similar company still exist?
      I appreciate that a new lead screw, if available, would be an expensive item. However I would rather buy a new one than pay around £70 for a second hand one, from the Bay. You never know what you are getting!
      Andrew.
      #8526
      Andrew Tinsley
        @andrewtinsley63637
        #280679
        ianj
          @ians
          Andrew.
          You can buy a new leadscrew from Myfords , £120 for the 5/8" diam or £134 for he 3/4" diam.
          Nick Hulme
            @nickhulme30114
            Have you considered doing the required machining and reversing the existing one? It only involves fairly simple work; turning, boring, sleeves, pins and locktite.
            That way you'd move the majority of the wear to where it isn't used and even if you do use that end you'll usually be using the side of the thread with least wear to drive the half-nuts,
            – Nick
            #280702
            DMR
              @dmr
              Andrew,
              You can buy lengths of Acme threaded bar leadscrew from industrial suppliers and cut it to fit your lathe, but you will need a bigger machine than yours to form the ends.
              Dennis
              #280796
              Andrew Tinsley
                @andrewtinsley63637
                Hello Ian,
                "Myfords" 5/8" lead screw is for theML7 with a gearbox. My ML7 is the one with change wheels Correct me if I am wrong, but the Myford one will not fit my lathe?
                Nick that is a smart idea, I didn't realise that it could be done. I shall take a close look and see if I can sort out what needs to be done.
                Dennis, that was exactly what I was on the lookout for. When I Googled lead screw manufacturers, I came up with loads of people doing small lead screws for CNC work (I presume). Can you give me a lead to a supplier of ACME threaded bar.My pal has a large Chinese lathe , so machining it up should be no problem.
                Thanks everyone! Hope is restored!
                Andrew.
                #280833
                DMR
                  @dmr
                  Andrew,
                  I typed "Acme" in the search box and found this quickly:
                  http://www.kingston-engineering.co.uk/downloads/standard-screw-datasheet.pdf
                  Bumps you to the top again in case anyone has other suggestions.
                  Dennis
                  #280852
                  Andrew Tinsley
                    @andrewtinsley63637
                    There you go! I still need some education on how best to use Google! My memory is not as good as it was (the kids think I am in the first stages of dementia!). Kingston rings a bell, I do believe it was the company that I looked at 30 years ago!
                    Thanks for the Google education,
                    Many Thanks,
                    Andrew.
