Myford ML4 leadscrew dials
Home Forums Workshop Tools and Tooling Myford ML4 leadscrew dials
Viewing 25 posts - 1 through 25 (of 37 total)
  • #478822
    Jon Cameron
      @joncameron26580
      Hello,
      As i hopefully near the end of the lathe refurb, i am wanting to add graduated dials for the leadscrew. I will be using the lathe for milling with an alomco milling attachment, (the base has an adaptor plate to fit the bed). With the half nuts engaged this should hopefully help to have small increments of movement using the leadscrew handle, instead of larger sometimes jerky movements when using the handwheel on the apron, which is direct drive onto the rack.
      Would i be right in saying with an 8TPI leadscrew i will need 125 divisions on the dial, so something like the ML10 dial would possibly be best. I have already become accustomed to using the dials as an approximation to finished size as i know there is the slightest of errors that Myford built into the leadscrews on the carriage and compound.
      Thanks in advance
      Jon
      Jon Cameron
        @joncameron26580
        #478843
        Hopper
          @hopper
          Yes. Each turn of the handwheel and leadscrew is 1/8" or .125" so you are correct.
          My M-type has had the outer diamter of the leascrew handwheel turned flat and the graduations and numbers etched on there. Works very well and very simple. Can be done on the lathe itself by using a plunger engaging with the change gears to index the chuck while holding the handwheel in it. Graduations are put on with a toolbit turned sideways and racking the carriage back and forth. A carriage stop can help get graduations correct length.
          I don't know about Myford building errors into cross slide feedscrews etc. Could it possibly be wear after all this time?
          Edited By Hopper on 10/06/2020 09:27:30
          #478854
          Jon Cameron
            @joncameron26580
            Hi Hopper,
            Yes i had considered that however given the time it would take and that a leadscrew handwheel with 125 graduations is available for £25 i am inclinded to take that route so was just checking. All i would need to do is make an adaptor to get to the 7/16" size as i believe though i need to check that the end of the leadscrew on mine has 1/4" BSF thread.
            With regards to the leadscrews Myford used 12TPI leadscrews in the earlier lathes, for the cross slide and compound which creates a small error not a lot but still there.
            Jon
            #478856
            Brian Wood
              @brianwood45127
              Hopper,
              Just to to avoid the suggestion that the 'errors' are deliberate, the feedscrews for cross and top slide on these early Myford lathes were made as 12 tpi square form, the dials were given 80 divisions so tool movement was an approximation. Myford say in their handbook that it is probably 'good enough for most purposes'
              Regards Brian
              Edit I see that Jon got there first with the 12 tpi screws.
              Edited By Brian Wood on 10/06/2020 10:16:56
              #478857
              Hopper
                @hopper
                Yeah that might be the smart way to do it.
                12tpi thats a bizarre one. Even my 1930s M type has 10.
                #478864
                Jon Cameron
                  @joncameron26580
                  Posted by Hopper on 10/06/2020 10:16:39:
                  I can only assume that it was designed so a new one could easily be made with a standard set of change gears if the need arose. Not sure if the standard set of change gears would allow a 10TPI thread? Brian would be better qualified on that one. As ive already said to him elsewhere i'm rubbish at maths hence the original question, i struggle working out gears and ratios. Took me a very long time for the penny to drop with dividing, but that's digressing!
                  Jon
                  #478865
                  Hopper
                    @hopper
                    Nobody works out change gears these days with online calculators available. My favourite is on the Little Machineshop site. 10tpi is doable so not sure about that. Maybe 12tpi was cheaper to buy on or something.
                    #478875
                    Brian Wood
                      @brianwood45127
                      Just to prove the point, 40 T on the mandrel and 50 on the leadscrew with idler(s) as necessary to link them will cut 10 tpi on any lathe with an 8 tpi leadscrew
                      #478876
                      Hopper
                        @hopper
                        I stand corrected. Brian is the last man who can still work change gears out in his head. smiley
                        #478877
                        Nick Clarke 3
                          @nickclarke3
                          I knew that Myfords took over manufacturing the Drummond 'M' type at the start of WW2 because, to quote lathes.co.uk "their contemporary models, the ML1, 2, 3 and 4, were completely unsuitable for professional work"
                          Could this be because of the inaccuracies in the slide leadscrews?
                          #478885
                          Jon Cameron
                            @joncameron26580
                            Posted by Nick Clarke 3 on 10/06/2020 11:42:46:
                            You might well have a point there Nick. I've never explored why they were unsuitable. Just accepted the powers that be didnt want to use myfords for whatever reason. Perhaps Tony has an answer on this if anyone is just that bit more curious than I.
                            Jon
                            #478903
                            Brian Wood
                              @brianwood45127
                              I'll let you into the secret Hopper, I use my calculator too!
                              Regards Brian
                              Edited By Brian Wood on 10/06/2020 13:49:53
                              #478917
                              Rod Renshaw
                                @rodrenshaw28584
                                Hi all
                                I can't remember where I got the idea but I have always understood that the reasons the ML1-4 were rejected for war time work was that they were regarded as too insubstantial for factory production work, and they lacked power cross- feed which made them unsuitable for use on smaller warships and submarines which bounce about too much to allow steady hand feeding. Hence Drummond were told to give Type M production over to Myford and further told to concentrate on producing Maximat ( not exactely sure of type or spelling) production lathes. In those days the Government could just tell everyone what to do and they got on with it!
                                Rod
                                #478937
                                  Posted by Rod Renshaw on 10/06/2020 14:52:13:
                                  Hi all
                                  I can't remember where I got the idea but I have always understood that the reasons the ML1-4 were rejected for war time work was that they were regarded as too insubstantial for factory production work, and they lacked power cross- feed which made them unsuitable for use on smaller warships and submarines which bounce about too much to allow steady hand feeding. …
                                  Rod
                                  Who would want them, and what for?
                                  Although they're maybe at the upper end in terms of quality, early Myfords are typical of any number of the basic pre-war machines sold to amateurs. Small, lightly built, simplistic, and relatively weak. Yes they do good work in skilled hands, but they're not robust and fast enough for production, or suitable for high-precision, or capable in the way valued for prototyping or laboratory work, or good for training servicemen and apprentices. Considerably inferior to Myford's post-war lathes, which killed the range stone dead, and to the contemporary and far more expensive Drummond M.
                                  I don't think anyone with production targets and tolerances to meet would want a pre-war Myford. For similar reasons, despite their many virtues, ML7 and Super 7's weren't popular in industry or education either. They prefer robust precision to delicate precision, and are prepared to pay big money for it.
                                  You don't see industry snapping up Chinese Hobby machines either!
                                  ega
                                    @ega
                                    I seem to recall my old school going over to Colchester Students in favour of the original Myford Sevens. On a later visit the Colchesters had gone, too!
                                    #478943
                                    Nick Clarke 3
                                      @nickclarke3
                                      Rod & Dave –
                                      The Drummond/Myford M Type, again according to Lathes.co.uk, "had been adopted some years before as the standard model for the Armed Services."
                                      The powered cross slide was only fitted to admiralty versions of the M type so most of these were not that different to the ML1/2/3/4 in specification, but were preferred for some other reason.
                                      Your points regarding the general capability of the lathe I acknowledge, as has been done elsewhere, but as far as I can tell most of these apply equally to the M Type as well as the ML series..
                                      Edited By Nick Clarke 3 on 10/06/2020 17:16:11
                                      Edited By Nick Clarke 3 on 10/06/2020 17:16:50
                                      #478945
                                      Howard Lewis
                                        @howardlewis46836
                                        With the original 80 division handwheels, each division would be 1.042 thou, which was probably not sufficiently precise. for the accuracy required.
                                        The closest that you can get to for a division on the handwheels to a thou would be to have 83 divisions.
                                        The error would then be x 10^-3 thousands of an inch in each division. The errors would probably then come from the thickness of the lines on the wheel!
                                        #478962
                                        Brian Wood
                                          @brianwood45127
                                          Hi all
                                          Rod
                                          That may be true Rod but I have a photo (in colour !) of a Mrs Luscombe who is featured machining a batch of Sten Gun firing pins. The lathe is quite clearly an ML4 in a back yard workshop so the work was being done by non factory based operators. She has had her hair done just for the picture too.
                                          #479032
                                          Hopper
                                            @hopper
                                            The M type also had a leadscrew dog clutch with carriage trip mechanism that would have been right handy for repetition production work. Also had a very solid "anvil style" bed that did not need levelling on set up and made it a very accurate lathe.
                                            I dont see the ML4 cross slide screw error as a big deal. Close enough for roughing cuts and on a 2 thou finishing cut the error is only .08 of a thou. Thats .00008" so not enough to worry about on a lathe where normal tolerance is .001" at best.
                                            #479047
                                            Jon Cameron
                                              @joncameron26580
                                              Posted by Hopper on 11/06/2020 00:04:41:
                                              Indeed, For my use i cant measure more than 0.0005" anyhow so the error is unnoticed unless it becomes accumilated by traversing the cross slide or top slide.
                                              I'm glad that this query sparked off some useful discussion, though my point wasn't intended to do so. Just relaid what id read, and as i said for some reason they had built an error into the lathe.
                                              Thanks for confirming my thoughts regarding the lead screw, at least i know in that direction i only have backlash of the half nuts to worry about, oh and disengaging the banjo from the spindle so i don't break the sheer pin (again), and watching that line so that i don't over cut on the first pass, oh and…………. lol
                                              Jon
                                              #479055
                                              Hopper
                                                @hopper
                                                I hear ya. I really miss the M Type's dog clutch when using my ML7 and have to pull the gear off the leadscrew to free up the leadscrew to use the graduated handwheel. So much so that i plan to make and fit a dog clutch to the ML7.
                                                Edited By Hopper on 11/06/2020 09:46:45
                                                #479056
                                                  Posted by Brian Wood on 10/06/2020 10:15:47:
                                                  Hopper,
                                                  Regards Brian
                                                  Just a thought …
                                                  The approximation is reasonably expedient for those working to decimal drawings
                                                  … Not dissimilar to the situation we currently see with some ‘Metric’ lathes.
                                                  So the underlying question might be:
                                                  When those early Myford lathes were first made, was anyone using twelfths of an inch ?
                                                  [*] remember that twelfths survived for a long time on school rulers, and that both ‘twelfth scale’ and 1:144 remain common.
                                                  #479058
                                                  Hopper
                                                    @hopper
                                                    I've never seen 12ths used — so they must be ancient. Quite possibly explains it though. Those early days they did a lot of turning with a rule and calipers. Micrometer? That were luxury that were.
                                                    #479067
                                                    ega
                                                      @ega
                                                      Twelfths:
                                                      Is there an indirect link with pounds, shillings and pence?
                                                      Twelve is a useful number for dividing purposes.
