I realise this subject has almost been done to death but…
The Myford oil gun is currently £80 incl. VAT. I have also read that even that gun leaks oil over time, or needs a cloth between it and the nipple to seal properly. This has led me, and I’m sure many others, to pursuing other options.
I have no end of oil cans and grease guns of varying qualities, but nothing that has really worked on the Myford nipples without significant leaking around the gun before the oil even got anywhere near the nipples. So far, I’ve had to remove the nipples to oil many areas, and the rest have been oiled with a grease gun, but the majority of the oil ended up all over me. There must be an easier way that doesn’t break the bank!
I understand that, without modification, the nipples need a high pressure to dislodge the sprung ball. I have a good oil can and tried attaching a very short length of hose to seal around the can spout and a nipple removed from the machine, but even though I pumped hard, no oil got through the sprung ball. I’ve read that some have used syringe needles, but I assume as this doesn’t force oil into the machine, many areas are left dry.
I noticed that several have mentioned using a Reilang oil can (around £31). These seem to be very good quality and very nicely designed tools, but are they able to oil the Myford nipples?
I've also noticed that the PressParts oil/grease gun (£17) has been recommended. Can anyone tell me whether this has provided a long-term solution, without modifications?
I also read many articles that mentioned Guy Lautard’s grease gun modification, but I’ve been unable to find his article online.
It would be interesting to find out how other (frugal) Myford users lubricate their lathes.
