Posted by Neil Wyatt on 20/08/2014 13:06:00:
… I find it hard to understand why Myford never used or moved to taper rollers, which were well understood by 1947 …
Neil,
I think you found the answer to that one, when you looked at the Adept:
A Taper Roller Bearing [or preferably a back-to back pair] in the Nose of a Headstock is fairly bulky 'diameter-wise' … Installing TRB in the existing casting would probably have compromised the Myford design, either in headstock strength or spindle diameter.
Without heavy modification to the casting … I think the plain taper bearing at the front with taper roller[s] at the rear is the optimum arrangement in the space available.
[ I hope the conversion goes well, Chris ]
