Most Useless Adaptor Ever
Home › Forums › The Tea Room › Most Useless Adaptor Ever
  • #253251
      I bought (for a very modest sum, just ofver £8) a kit of three 52 front filters plus an adaptor for my bridge camera off the 'bay.
      Now despite what the ad said, for P520 and P530, the web suggests that the p520 (my camera) doesn't actually have a thread, just parallel rings. But as the 'thread' is interrupted, I thought I might bodge it on or even turn off the thread and glue it in place.
      The 'adaptor ring' which I expect does fit the P530 has an interesting property. It has a 52mm x 1mm pitch female thread for the filter on one side.
      On the camera side it has a 52mm by 1mm pitch male thread…
      Thankfully the filters seem to be quite good. The UV is branded Kenko and was boxed and in a foam +plastic case, so worth the price of the whole caboodle.
      The other two are branded RISE(UK) and appear to be cheap as chips from this UK wholesale operation, but the circular polariser does a great job.
      The other is a FLD meant to get rid of green casts under fluorescent light so pretty redundant these days with auto white balance, but it may serve as a 'gentle' nebula-boosting filter cutting blue to orange up to 50% while letting through more violet and a lot more red. Worth an experiment.
      #34727
          Neil,
          Is the 'useless' aspect the 1mm pitch ?
          … Don't think I've ever seen a screw-threaded camera filter that wasn't 0.75mm pitch
            I think the useless bit is that you are adapting the camera thread to what is essentially the same thing eg start with 52mm female and end up with 52mm female, pitch makes little difference.
            Unless it adapts 1.0mm to 0.75mm?
            #253271
              Sorry, yes, it's 0.75 both sides. The last camera thread I cut was for an M42 adaptor which is 1mm pitch.
              As Jason says it sis more of a 4mm (ish) extender than an 'adaptor'.
                Should be nice for adding some creative vignettes.
                  idea
                  Could it be that the front element of the P530 lens protrudes a little into the filter-thread length ?
                  It's just possible that these 'slim' filters would touch the front element [hence making the 'useless' adapter very useful indeed].
                  … Just a thought
                  Bazyle
                    @bazyle
                    I have some 'adaptors' that are the same size & pitch each end, called 'rings' they are for moving the lens further away to provide a macro function, like bellows in fixed increments.
                    #253358
                      Posted by Bazyle on 31/08/2016 23:26:28:
                      … and very useful they are, too
                      But Neil's "adapter" ring fits on the front of the lens, in the filter thread.
                        Yes, I have a set of M42 extension tubes
                        All this 'adaptor' does is fit in the space where a filter could fit.
                        … well that was embarrassingly easy, i just spent a couple of minutes turning off the thread and making it a close push-fit in the front of the camera.
                        It does cause minor vignetting at the shortest zoom so I will only use it when needed, but it opens the door to using my old 52mm filters and even my Cokin holder.
