Hi Guys
I am asking the question of "how well does a Morse taper 2 collet release in the spindle of a mill"
I usually use a Clarkson type chuck with collets in the Tom Senior mill.
as some of you might know, that can limit the hight of the work.
so I was thinking, as and when I had to, I could use a Morse tapper collet instead and do away with the Clarkson chuck.
my only concern is how easily it will release if tightened up properly for milling
I DON'T WISH TO, nor do I EVER smack the draw bar with a hammer to release the Clarkson chuck!!!!!
I have made a release type clamp, based on a ball joint splitter (not the hammer type) that I use when removing stuff from the spindle,
with the Morse taper collet fitting directly in the spindle, Ill have nothing to help with removal of said collet
