ML4 Phospor Bronze Bearings
Home Forums Manual machine tools ML4 Phospor Bronze Bearings
  • #53885
    Barneyboy
      @barneyboy
      Hi all  can anyone recomend a source of supply for replacement bearings to suit an ML4 Myford lathe.
      Thank you bernard25@tiscali.co.uk Glasgow
      Barneyboy
        @barneyboy
        #53887
        Bogstandard
          @bogstandard
          When I restored my old ML lathe, I made my own phos bronze bearings to match the spindle after it had been ground down to take the wear out of it  (only about 0.002″), but it was enough to make a ready made bearing a sloppy fit.
          To put that much strain and deformation on the castings to take that play out would have maybe caused serious damage to the castings.
          I would suggest you mic everything up, and make the bearings yourself, it is only a fine boring and turning job.
          Bogs
