ME Thread helicoil
ME Thread helicoil
  • #569490
    Chris Evans 6
      @chrisevans6
      Are helicoil inserts available in ME thread ? I have some Amal carburetor tops to repair 7/32×40 tpi. If not available I will make brass inserts and Loctite in position, my searches so far have not found ME inserts.
      Chris Evans 6
        @chrisevans6
        #569491
          Never say never … but I really doubt if such items exist. sad
          #4-40 UNC is common though … so it’s not the fine pitch that’s the problem
          Edited By Michael Gilligan on 02/11/2021 21:03:28
          #569492
          Chris Evans 6
            @chrisevans6
            Thanks Michael, I doubt there would be a market for them. Brass inserts will do the job.
            #569499
            duncan webster 1
              @duncanwebster1
              Can you open up to 1/4*40 and then make some stepped studs
              #569520
              Chris Evans 6
                @chrisevans6
                Posted by duncan webster on 02/11/2021 22:23:10:
                The thread is 7/32×40 for the cable adjuster so 1/4×40 may not give enough wall section for thread depth. I will look at 7mm or 9/32" depending on which taps and dies I have. Thanks for the input.
