Martin Gearing Wooden Oscillating engine
Home Forums General Questions Martin Gearing Wooden Oscillating engine
  • #385563
    anthony brooks 3
      @anthonybrooks3
      Hello. Does ………………………………………………………………………book? A friend's child wants to 'make something,' and I thought this would be a good project for her. The book is not available in the US and postage from the UK to US is prohibitive.
      Alternative project suggestions are welcome.
      Merry Christmas and a prosperous 2019 to you all!
      Edited to remove possible copyright infringement
      Edited By JasonB on 14/12/2018 08:08:35
      anthony brooks 3
        @anthonybrooks3
        #385574
        Hopper
          @hopper
          Freight prohibitive? Four dollars direct from Camden Miniature Steam publishing website. Eight dollars on Amazon UK. (Never buy books internationally from Amazon if you can avoid it. There's always somewhere cheaper.)
          Looks like a great project for a kid. ( I might have to make one myself.)
          Edited By Hopper on 14/12/2018 07:53:35
          #385578
            Assuming that Mr Gearing is not of very small stature … The engine is bigger than I expected
            https://www.energybook.co.uk/Build-a-Wooden-Oscillating-Engine.html
              That is a lot bigger than the cover photo makes it look, would need a hefty compressor to get that one running.
              #385586
              RichardN
                @richardn
                I’ve seen several of that sort of size that work well from a vacuum cleaner though… if a bit noisy…
                #385589
                  That would make sense as I'm sure they don't get used under load so HVLP would be fine.
                  #385641
                  anthony brooks 3
                    @anthonybrooks3
                    Post was 9 pounds on one of the English sites. I had not considered AmazonUK. US Amazon has a used edition for over $50!
                    It is made to run off a vacuum cleaner and is aboout 300mm high.
                    I will keep looking on the sites you mention.
                    #385645
                    anthony brooks 3
                      @anthonybrooks3
                      Thanks for the Camden books link. I will be using them.
                      #386402
                        If you have not ordered yet then I noticed that it was in Model Engine Builder mag a while ago, you can get digital back issues quite cheaply, all the drawings are in issue 24 along with 2 pages of text.
                        #387330
                        anthony brooks 3
                          @anthonybrooks3
                          Thanks for the lead. I purchased the book a day earlier. The magazine looks very interesting.
