Marlow millers and warco’s
Home Forums Beginners questions Marlow millers and warco’s
Viewing 23 posts - 1 through 23 (of 23 total)
  • #6542
    jason spencer
      @jasonspencer41535
      Trying to decide on purchase
      jason spencer
        @jasonspencer41535
        I'm looking at purchasing a marlow 3A, however i've also looked at a warco VMC.
        Does anyone have any infomation/opinions on the two machines above?
        The Malow is a little larger and about 200kgs heavier, its 3phase so will need an inverter however its only a 1hp motor so for £100 i'll have variable speed etc.
        #110080
        chris j
          @chrisj
          Posted by jason spencer on 26/01/2013 09:34:49:
          I have a VMC and think it's pretty good.
          The paperwork that you get from Warco will be extremely poor only matched by the level of service !!
          #110092
          Springbok
            @springbok
            I converted all my machines some years ago you will not regret it. Warco the quality for the same model varies but like the old saying "That must have been a friday afternoon car" I personally purchased a Chester 626 and have never had many problems.
            Bob
            #110093
            Springbok
              @springbok
              Have just looked up Marlow on Google I have to say there is no contest if you can get it.
              Bob
              #110094
              John Stevenson 1
                @johnstevenson1
                I used to have a Marlow 3A some years ago and found it to be a very basic machine.
                Only kept it a couple of months as the lack of a quill feed I found to be most anoying and time consuming. Also the tilting head was limited in travel and as a lot of my work was on motor cycle cylinder heads it meant they had to be setup at an angle as opposed to bolting down flat
                If I had to make the choice today I'd go with the VMC hands down.
                #110096
                jason spencer
                  @jasonspencer41535
                  They guy claims it doesn't have the option.
                  These are the marlow pics of whats there, a few cutters etc too.
                  Basically the marlow is £850 in my garage…
                  The warco is a VMC, with the following and is £1k plus collection costs
                  Clarkson Autolock Chuck R8 Taper with 8 collets metric and imperial.
                  Heavy milling vice 6 inch
                  Reground Milling cutters to suit Autolock chuck most not used. about 30-40
                  Rotary table 6 inch
                  Clamping Kit
                  keyless drill chucks 2 RB with adapter
                  2 R8 indexable facing cutters
                  Acc-rite Imperial 2 axis DRO with acc-rite scales
                  Single phase motor just had a new on/off/reverse switch
                  People are of equal opinion so far!
                  #110110
                  blowlamp
                    @blowlamp
                    The lack of a quill will make the Marlow quite tedious to use when it comes to drilling and reaming.
                    I used to have a Boxford miller, which, like the Marlow, has no quill and is wasn't very long before I swapped it for a Myford VMC – and this proved to be a very good move for me, but even the Myford doesn't have a fine downfeed to the quill, whereas I think the Warco and Chester versions do, so you might be better off with one of those, in my opinion.
                    Martin.
                    #110112
                    Roger Vane
                      @rogervane67137
                      Totally agree with Martin – the lack of quill will make the Marlow very difficult to use, so unless you just need a machine just to mill, rather than mill and drill, I would advise that the VMC would be the better option for you. You are likely to have to live with the machine for a number of years, so making the right choice now is important.
                      The only issue that I've got with the VMC is the distance, or rather lack of it, between the spindle nose and the table. This can give real problems when trying to use long drills on tall jobs.
                      Hope this helps.
                      Roger
                      #110114
                      blowlamp
                        @blowlamp
                        Posted by Roger Vane on 26/01/2013 15:55:11:
                        Hope this helps.
                        Roger
                        I managed to acquire a 100mm spacer block from Myford and that made a nice improvement to this machine.
                        Martin.
                        #110117
                        John C
                          @johnc47954
                          Hi Jason,
                          I have a Chester 626 – same as the Warco – and am very happy with it. I agree about the quill – most useful. Also the Warco you are looking at appears to come with a DRO. I would say this is a huge advantage which wil make your milling so much easier.
                          Blowlamp -was your spacer a Myford part or home – made?
                          Rgds,
                          blowlamp
                            @blowlamp
                            Posted by John Corden on 26/01/2013 16:44:26:
                            Rgds,
                            It's a genuine Myford part – and in the correct shade of green too, which is slightly different compared to the lathes.
                            I think the retail price was around about £180 if my memory serves me well, but they discounted by about 50% because they had never sold one – extended studs, washers and nuts were also included as part of the kit.
                            Martin.
                            #110126
                            John C
                              @johnc47954
                              Ok, Thanks. At that price, no wonder they never sold one!
                              John Stevenson 1
                                @johnstevenson1
                                Will be doing some 75mm and 100 mm spacers later on in the year, just sold the last one of the second batch I made.
                                #110185
                                Peter Seager
                                  @peterseager57150
                                  Will they fit Myford or Warco VMCs or both?
                                  Peter
                                  Edited By Peter Seager on 27/01/2013 10:32:43
                                  #110201
                                  John Stevenson 1
                                    @johnstevenson1
                                    Both,
                                    They use the same base casting.
                                    #110203
                                    blowlamp
                                      @blowlamp
                                      Posted by John Stevenson on 27/01/2013 12:26:57:
                                      Both,
                                      Am I right in thinking that the Myford is a two stud fixing and the Warco & Chesters are three stud?
                                      Martin.
                                      #110205
                                      Steve Talbot 1
                                        @stevetalbot1
                                        I've had a Warco VMC for several years and have found the following mods very useful
                                        DRO essential in my opinion
                                        6" head raising block. 4" probably all that's required
                                        Spindle lock to make tool changes easier
                                        Draw bar release tool
                                        Inverter Drive very useful.
                                        Problems;
                                        Original machine travel specs. did not match catalogue
                                        Table soft easily marked
                                        One shot oiler not very good some points over oiled other starved of oil.
                                        Would be useful if Y axis travel was greater.
                                        Steve T
                                        #110206
                                        Tony Pratt 1
                                          @tonypratt1
                                          Martin.
                                          My Myford VM_E has 3 studs
                                          Tony
                                          #110207
                                          John Stevenson 1
                                            @johnstevenson1
                                            The ones I do are 3 stud at 12mm diameter.
                                            OD is 6" / 150mm
                                            #110209
                                            Steve Talbot 1
                                              @stevetalbot1
                                              I found that the bolt holes on my Warco were not on the same PCD or equidistant!
                                              #110212
                                              blowlamp
                                                @blowlamp
                                                My machine is a Myford VMC (mid 1980s), so is a bit smaller than the current models now offered by Warco & Chester and thus has a two stud fitting.
                                                Martin.
                                                #110239
                                                John C
                                                  @johnc47954
                                                  John S, can you give a ball park figure for price on your spacers?
                                                  Thanks,
