Making new gib strip for cross slide
Home Forums General Questions Making new gib strip for cross slide
Viewing 25 posts - 1 through 25 (of 30 total)
  • #473224
    Rowan Sylvester-Bradley
      @rowansylvester-bradley37244
      I have just discovered that the cross slide on my Portass PD5 lathe is missing its gib strip. What is the best way of making a replacement? It needs to be 3mm thick, 12mm wide and 230mm long. Do I make this from gauge plate? If so, do you know of anyone selling 3mm x 12mm gauge plate (I can only find 3mm x 10mm, which would at a pinch be OK but 12mm would be better)? What is the best way of making the conical recesses for the pointed grub screws (there are 5 of these) to locate into? Do I need to heat treat the gauge plate once I have got it to the right size and made the 5 recesses? If so, how?
      Thanks – Rowan
        #473232
          Gauge plate is for hardening and I see no advantage in hardened gib strips.
          I'd go for brass because it's easy to work and polish, and there's a nearby standard size. Cast iron would be OK but maybe awkward to source in that size, or mild-steel for cheapness (but more difficult to shape.)
          Dimples can be pretty crude as long as they're in the right place – a centre punch.  Posher to cone them out with the end of a drill, and best of all to cone them at the correct angle so the screws align nicely.  Not sure dimples make an enormous difference unless the gib tends to tilt, their main purpose is to stop the gib sliding out
          Edited By SillyOldDuffer on 20/05/2020 12:52:18
          #473234
          Andrew Tinsley
            @andrewtinsley63637
            I have used gauge plate for gibs without hardening. It is an easy way to get good dimensional accuracy stock without any fuss. What is more, they work exceedingly well in practice. The oldest one that I have made, has done around 35 years of service with no problems.
            Andrew..
            #473238
            Peter G. Shaw
              @peterg-shaw75338
              My very limited experience suggests that mild steel will be satisfactory, especially if the cross-slide is made of cast iron.
              I had to make some new gib strips for my milling machine and used mild steel which I attempted to scrape flat, ie I don't know how good they were! In respect of the recesses, what I did was to make a suitably sized screwed tool to fit the existing adjustment screw holes (you only need one tool). This tool was screwcut in the lathe and had a hole drilled through it to take a suitable sized drill for the recesses (or dimples). The idea being that as both thread and hole were made without removing the tool from the lathe, then both thread and hole would be concentric. Now, with the tool inserted into screwed hole on the cross-slide, and the gib strip clamped up tight against the inside of the dovetail, then by gently inserting the appropriately sized drill into the tool, a conical recess can be carefully drilled, at an angle, into the gib strip. In other words, the tool acts as a guide to locate the drill which creates the recess.
              Peter G. Shaw
              #473240
              Hopper
                @hopper
                Plenty of 1/8 x 1/2" gauge plate on ebay. Would that do?
                No need to heat treat. Comes ground flat. Wont crack like cast iron or embed swarf particles as easily as brass.
                Divots for the screws are done with a drill poked down the screw hole while strip and cross slide are clamped in position. Round the ends of screws to a hemisphere to sit nicely in the divots.
                #473251
                  I agree with Andrew & Hopper
                  … and incidentally, this choice has been discussed quite recently.
                  Edited By Michael Gilligan on 20/05/2020 14:11:22
                  #473256
                  John Baron
                    @johnbaron31275
                    Hi Guys,
                    In general I agree ! Brass would be my material of choice, and it comes in 3.2 mm thick by 12mm (actually 1/8" X 1/2" X 12" ) but mild steel would be good too.
                    Edited By John Baron on 20/05/2020 14:42:46
                    Edited By John Baron on 20/05/2020 14:43:10
                    #473261
                      Thanks for all the advice. I have ordered a piece of 1/8" x 1/2" gauge plate. Will this be too hard to make the dimples with an HSS drill or countersink bit? Thanks to Peter G. Shaw for the idea about the drill guide tool. I'm not sure that my screws are big enough to make this practical – it would be a very small drill. And drilling through the holes without such a tool sounds very difficult to do without damaging the threads. I think it may be a case of marking through the holes onto the strip of steel, then making the dimples on my pillar drill. But all that fun comes after the strip has arrived…
                      Thanks – Rowan
                      #473266
                      John Baron
                        @johnbaron31275
                        Hi Rowen,
                        Buy a length of silver steel rod and make a spotting tool. Its just a length of rod of the right diameter to pass down the hole with a point on the end turned in the lathe and the end hardened. A quick tap with a hammer and done. Dimple it on the drill press.
                        #473269
                        David Davies 8
                          @daviddavies8
                          Rowan
                          If you pin the gib strip to the cross slide using a piece of 1/8" silver steel, as described by George Thomas in his "Model Engineer's Workshop Manual" this will prevent movement of the gib. The dimples will not positively locate the gib to the screws.
                          I have carried out this mod to both Boxford and Myford lathes. This included making a new gib strip on one of the machines for which I used bright mild steel. I'm sure the method could be applied to the Portass.
                          HTH
                          HOWARDT
                            @howardt
                            The gib strip material should be more wearable than the mating material. You have a long bedway, which is cast iron and may be hardened to a degree, a short gib which is short and harder than the way will wear a local length close to the chuck. The difference in hardness doesn't have to be much, they could be equal and still have damaging consequences. You can adjust the gib to take out its wear but you cannot adjust the way. On hard ways gibs were originally cast iron then later fitted with Turcite with the slides I used to design and work with, these were for high production machines were movement over a day could be measured in kilometres.
                            So my advice would be brass, cast iron or a soft steel.
                            #473298
                              Could someone copy the relevant pages of George Thomas "Model Engineer's Workshop Manual" for me, assuming that there are not too many? There seem to be no copies of this book at prices less than hundreds of pounds.
                              Thanks – Rowan
                              #473299
                                I read somewhere many year ago that actually the harder material wears more, because abrasive particles get embedded in the softer material, and these then wear the harder material. I can't say that I have ever observed this in practice.
                                Also the gib strips that I do have (on the saddle and on the combination slide) seem to be made of some hard grade of steel.
                                Any further thoughts on gauge plate vs brass?
                                Thanks – Rowan
                                #473303
                                Oldiron
                                  @oldiron
                                  Posted by Rowan Sylvester-Bradley on 20/05/2020 16:35:39:
                                  Thanks – Rowan
                                  Still in print so presumably copyrighted. Available for less than £30 here
                                  regards
                                  #473304
                                    Posted by Rowan Sylvester-Bradley on 20/05/2020 16:40:45:
                                    Thanks – Rowan
                                    My further thought … You have observed traditional and well-proven design.
                                    Andrew Tinsley
                                      @andrewtinsley63637
                                      Never used brass, but gauge plate works for me. I have not had problems with bed wear either. Then I don't move the saddle kilometers a day. What is needed for high speed modern machinery is not very applicable to ME.
                                      Andrew.
                                      P.S. Correct and regular cleaning and lubrication is more important than gib material.
                                      #473317
                                        Posted by Oldiron on 20/05/2020 16:45:09:
                                        Thanks – Rowan
                                        regards
                                        Thanks for pointing this out. For some reason Google failed to find this, and I just assumed it was out of print so didn't try the original publisher. Unfortunately they seem to have shut up shop for coronavirus, and their web site is not allowing me to order anything. So I've still not been able to order it.
                                        Thanks – Rowan
                                        #473345
                                          A supplier of brass 'upgrade' gibs told me they felt they were just 'upgrade bling' but as people wanted them, they met the demand.
                                          I've made gib strips out of steel and brass, hard (non-compo) brass was actually the worst stuff to machine a gib from, but they all worked OK in the end..
                                          Clive Foster
                                            @clivefoster55965
                                            Rowan
                                            Many years ago I did a write up of my version of the GHT improved gib with a bit more background information, but no pictures, for an American acquaintance. I'm inclined to think I actually stole the idea from Smart & Brown before seeing Georges write up.
                                            Unfortunately the nice version disappeared into computer black hole space around the millennium but I still have a rougher, E-Mail format, version that might be good enough. PM me your E-Mail address if you'd like a copy. Might take a day or two to find it tho'!
                                            I've done my full monty version to several small lathes in the Myford / Boxford et al class with excellent results making up for what often seems like far too much wear. When doing this sort of thing to an older machine its worth remembering that old oil varnish build up to embarrassing thickness over a decent fraction of a century. Especially if cheap automotive and similar lubricants have been used. Darn difficult to shift it but worth the effort. I swear its ahrder than the cast iron. My experience is that something like half the apparent "wear" on an old, shed living, machine is due to uneven oil varnish build up in the wrong places.
                                            #473353
                                            Jon Cameron
                                              @joncameron26580
                                              I've been watching this thread and replies with interest it was a question I was going to ask.
                                              I intended to use black steel, and then Polish it on plate glass with fine abrasive paper. Working upto using simply some brasso or autosol, on the backing paper. The gib I have is too thick for the new saddle I have for my ML4. The old one had been previously machined and included a 10thou error when traversing the cross slide from front to back. (Ie was higher at the far end than when it started it's journey).
                                              The whole bed needs grinding or scraping, but it isn't a skill I've practiced and will leave that for another day, also on the ML4 is not likely to see any return in any future sale/upgrade, despite the return of accuracy over the next few years of using it. But that's another story.
                                              Edited By Jon Cameron on 20/05/2020 19:06:19
                                              #473428
                                              Clive Foster
                                                @clivefoster55965
                                                Jon
                                                I never found any great advantage in going silly on finish or material specifications beyond decently smooth and dead straight. Used a bit of thick zintec once as it was the right thickness. But that was on a 6" Abwood vice, intercepted in mid flight to a friends scrap bin, then fitted with possibly the worst gib strip ever seen. Tapered in all directions with no straight edges and bent to boot. I think an apprentice was trying to clean the vice out, broke the proper cast iron strip and tried to cover up with what he could find. It actually worked quite well all things considered. Post rebuild performance is awesome but I hardly use it as its so heavy!
                                                What I have found is that the strip needs to fill the gap as closely as possible and to sit tight up into the corner of the dovetail recess. If using the GHT system of ball ended screws in proper conical recesses there is some upward force keeping the strip in the corner. Especially so if you subsequently fit a dowel as specified by GHT with the strip tightly forced up into the corner. Messrs Smart & Brown used two dowels. This would seem to get you as close as possible to the ideal "solid but adjustable" set-up when using a conventional gib strip. (I guess the bolt up block used on some Colchester machines is theoretically best.) Such careful location lets you run the gib with minimal clearance given patience to get the adjustments exactly right.
                                                #473434
                                                Hopper
                                                  @hopper
                                                  Posted by Jon Cameron on 20/05/2020 19:05:57:
                                                  That should work. No point in going overboard on a thin gib strip that is going to flex to conform with the adjusting screws anyhow. All it does is hold things in position. Cutting forces are borne by the opposite solid dovetail surface.
                                                  #473445
                                                  Pete Rimmer
                                                    @peterimmer30576
                                                    Jon,
                                                    Steel is fine for a gib strip but the very last thing you want is a polished surface. It leaves no room for the oil film and promotes stick-slip and wear. Milling a piece of steel to thickness and using it as-is would be preferable. Scraping the finish on it would be better still.
                                                    Rowan.
                                                    Brass is easy to work and looks good but it's a poor choice of material for a gib strip. It's too soft and will pick up dirt which then starts to lap the opposing face. The contact face polishes up quickly and then wrings out the oil film as above. Brass also tends to smear if lubrication is even mildly neglected.
                                                    Steel is a good material, so long as you don't use something super-gummy. Unhardened gauge plate is very good. Cast iron is also very good material for gibs. A nice hard bronze would also be good, again with a milled or scraped finish.
                                                    #473450
                                                    David Davies 8
                                                      @daviddavies8
                                                      Hopper commented:-
                                                      "Cutting forces are borne by the opposite solid dovetail surface."
                                                      Yes, but one exception is the Boxford top slide. Heaven knows why they made it that way round. I presume that the Southbend and all its other clones are the same?
                                                      Cheers
