Hi,
I wonder if anyone has any suggestions to help me lift a Downham mini jig borer. When I picked it up the seller was very helpful and loaded it onto a pallette and into the van on a forklift. However I'm having a bit more trouble than expected at this end.
My equipment is: home built gantry crane, a 2 ton pallette truck. 1 ton chain lift, 5 short webbing slings and 1 long one. Plus random ropes and webbing etc
I think my main problems are concerns over where to safely attach to without risking damage to the machine, and the fact that it wants to tip and roll like crazy. It's currently laying on its side on a pallette. I need to get it up over a 10in concrete slab and then up 10 inch step into my workshop.
This is the forth time with this equipment, first (and second, but that's a longer story) with a Warco WM280V lathe and also an old Newing Hall Pantocut. In theory that was heavier but also seemed designed with lifting points in the castings. This Jig Borer has none of that. When the chap lay it down, he locked off the moving head to the column and lifted with that?? Is that ok? The last thing I want to do is damage it, as it's in lovely condition.
I've linked to some pictures of the current machine and also one of the crane in use moving the lathe in its crate.
https://photos.app.goo.gl/ZvNzN346yTj9z6ZR6
Any thoughts?
Thanks in advance.
Steve
