Posted by old mart on 03/08/2021 19:52:52:
The only thing that matters is whether the lathe turns metal well enough for your purposes. I doubt whether 5% of lathe owners have ever leveled their lathe.
As I see it, levelling to the nth degree might well be advantageous for a lathe with long bed and multiple supporting feet along its length, but….
For most hobby lathes, with feet at either end only, it is a waste of time as when ‘levelled’ the lathe may not cut parallel and require shimming under a foot to remove bed twist. Turning parallel is the ultimate test with no real substitute.
Tailstock height adjustment seems irrelevant to me if the lathe is only secured at both ends – it might be correct when close to the spindle, but what would alter it at the end of the bed – unless it has multiple feet (more than two pairs)?
I’m perhaps one of the 5% (or is it 95%?). My lathe was made to be ‘free standing’ – only being bolted down tightly at the headstock end, with the tailstock end just lightly supported by a single bolt, with a spring, at the tail end. Only if the lathe cuts off-parallel are shims, on one side, advised I believe. I levelled the base such that any fluids would drain away, rather than collect at one end/corner.
___
Derek,
That container vessel, which got stuck in the Suez Canal, has just arrived at the UK. Was your lathe on that?🙂
