Posted by Barrie Lever 1 on 13/08/2018 00:02:08:…
…a stepped shaft made in free machining aluminium, 5mm dia going to 6mm and then 8mm, length of the 5 and 6 mm dia sections is 35mm each ….
That's a long thin job that is going to be subject to quite a bit of flexing. I would suspect this aspect, or some defective material that has a hard spot etc through it, rather than a lathe malfunction. You are right, chuck etc should not cause out of round turning. It should "find its own centre" as you say.
Are you using a tailstock revolving centre? Is it running true, or running a tad out of whack? Maybe try a fixed centre?
Are you using HSS toolbit? Carbide tooling might tend to rub and cause problems on a long thin ally job like this.
Have you tried some test pieces of other, larger material to see if they do the same? If the problem is a lathe defect, it should show up on a piece of half-inch steel bar or even larger turned in similar manner with tailstock centre support. If they turn OK, then the problem would seem to be either the material, or the long thin nature of the aluminium job you are attempting. You may have to make some kind of travelling steady to support that job. Or turn it in shorter sections, sliding the stock out of the chuck/collet as you complete each shorter section.
