lathe belt
lathe belt
Home Forums General Questions lathe belt
Viewing 7 posts - 51 through 57 (of 57 total)
  • #60103
    blowlamp
      @blowlamp
      Posted by Dinosaur Engineer on 07/12/2010 16:00:42:
      Maybe the toothed belt is used due to a small pulley being used  ( high torque at small radius) and the pulley wheel centres are close so that it’s difficult to provide enough “wrap around” for a ‘V’ belt. A friction belt would be better than a “geared” belt as it’s more likely to slip rather than cause mechanical damage. The equivalent ‘ v ‘ belt drive would probably need more space and/or a tensioning roller to increase the small pulley “wrap around”
       I agree with all of that and would say that if a small ‘toothed belt’ drive pulley is used, then that is probably a bad thing in this instance, as the belt will be prone to shedding its teeth.
      Poly-V belts are much better under these circumstances, due to their slim construction and will wrap around smaller pulleys than other V-belts, but do need to be properly tensioned.
      If the lathe in question has inadequate tensioning arrangements then that might be why the maker went with a toothed belt design, as it is more forgiving if left loose.
      Almost all other manufacturers use V-belts of one style or another.
      Martin.
      Terryd
        @terryd72465
        Hi Dinosaur and Blowlamp,
        Those are very likely to be a couple of the reasons for hte decision to use these belts.  Dinosaur surely the slip factor is built in to the other (vee) belts from the countershaftand if Poly bets were used with their better grip it would tend to decrease the safety factor element.?
        Terry
        #62279
        Gordon W
          @gordonw
          Just for interest:_ Have now got a new toothed belt for my Chester DB8 lathe. Well bought 2, following up suggestions on this forum, from Lathemaster in Baton Rouge US. Very helpful man, only prob. was Royal Mail charging £11.90 “handling fee”. Pity I couldn’t have got one from Chester.
          #74677
          ncd
            @ncd
            Hi,
            Just as an update to this – I also tried to get the belt for my DB8 from Chester who were very helpful but it seems there may be two designs of DB8 out there. they very kindly offered to source one for me but I chose to try locally first.
            Mine uses the older style wide belt which I bought from http://www.brammer.co.uk in case anyone else faces this in the future.
            Cheers,
            N
            #205436
            Ron Shaw
              @ronshaw11131
              This was interesting as i have the db10g and same issue, want spare belt, mine listed in manual as an M1.5xZ124
              Can you give me the part no for the ones you bought?
              Also i love the lathe so would like to mod pulleys if these belts cant be readily found as it would seem
              Hoping we can keep this alive
              Ron
              #205473
              mahgnia
                @mahgnia
                C6 spare part:
                C6-944 Timing belt from Arc-Eurotrade 1.5 x 124 x 15
                Edited By mahgnia on 23/09/2015 15:30:25
                #205532
                Ron Shaw
                  @ronshaw11131
                  Thanks a bunch there Andrew!!
                  Great link mate
                  cheers
                  Not same lathe as mine but parts like belts same though
                  Edited By Ron Shaw on 23/09/2015 22:46:55
