Large Pulley wheels
Large Pulley wheels
Home › Forums › Materials › Large Pulley wheels
  • #418080
    Speedy Builder5
      @speedybuilder5
      Perhaps an unlikely source of V belt pulleys is spare parts for ride on mowers – typically the drive pulley on the gear box / rear axle is about 225mm diameter.
      BobH
      #29934
      Speedy Builder5
        @speedybuilder5
        #418083
        not done it yet
          @notdoneityet
          I see lots and lots and lots of belts at some auctions. Unfortunately, unless you know exactly what you are looking for and it is there, mostly a dead item to bid on.
          Same goes for hydraulic pipes – buy a huge amount for peanuts and only use a couple – then have to offload them or dump the rest. Still a huge saving on the couple you can use, though!
          Certainly found it better to buy the I need from a local stockist as they are not an expensive item – apart from timing belts
          #418159
          Ian S C
            @iansc
            Old washing machine/clothes dryers, a bit over 12"(I think) A section belt.
            Ian S C
          Home › Forums › Materials › Topics
