Key ring project
Key ring project
Home › Forums › The Tea Room › Key ring project
  • #35560
    Plasma
      @plasma
      #420417
      Plasma
        @plasma
        Hi all,
        Just a daft little project to pass an hour or two in the workshop.
        Titanium bar turned to make a plug and socket affair.
        Neodymium magnet in each end, make sure you observe polarity.
        Couple of M5 lifting eyes and bingo. A key holder that is easily detached from your belt.
        #420418
        Mick B1
          @mickb1
          Heat it carefully and it'll go an amazing blue.
          Edited By Mick B1 on 22/07/2019 21:37:30
          #420462
          Nicholas Farr
            @nicholasfarr14254
            Hi Plasma, nice looking idea, but could the key or the holder catch on something accidently as you pass by and you not notice that it's gone, or an opportunist trying their luck.
            Regards Nick.
            #420471
            Trevorh
              @trevorh
              Morning Plasma
              That looks good, did you have any issues tapping or fitting the eye bolts – i am guessing they are not titanium ? I was thinking back to when I use to use it a lot in Petro chem and we were always warned of dis similar materials and Titanium
              either way it looks good
              trevor
              #420473
              Plasma
                @plasma
                I've not tested the breakaway strength but having worn it around the house and garden and not suffered any detachments it seems ok.
                I did worry about loss and so a security chain is clipped on when out and about.
                Only problem was in tapping the titanium, it's tough stuff so I took things nice and steady.
                It's quite convenient in use as you just pop your keys off, sort the lock and then they clip back together really smoothly.
                Similar thing on a gadget website set me thinking about the idea.
                Plasma
                #420474
                Plasma
                  @plasma
