ISO Container for Workshop
Home Forums General Questions ISO Container for Workshop
  • This topic has 24 replies, 18 voices, and was last updated 1 July 2020 at 19:39 by Robert Atkinson 2.
Viewing 25 posts - 1 through 25 (of 25 total)
  • #483033
    Andy Carruthers
      @andycarruthers33275
      House move soon has led me to think about how to shift my small workshop. I am thinking to buy an ISO lorry container probably 8ft x 40ft as I expect a second move in a few years time therefore portability is a further consideration. I’m prepared to fit out the container myself as a project and can store my tools in the mean time
      Has anyone done this, I expect condensation to be a consideration so I’ll line it, your thoughts please
      Andy Carruthers
        Using an ISO container for workshop
        #483036
        DC31k
          @dc31k
          Immediate thought is 2 x 20 foot might be so much easier. Transportation, equipment for installation, access and space for installation, foundations are all simplified with a smaller unit.
          #483039
          Bo’sun
            @bosun58570
            Sounds like a relatively simple and secure solution, but as you recognise, condensation WILL be a problem. Forced ventilation and insulation will certainly help. Finances permitting, a pre-insulated fridge/cold box type container might save a lot of work.
            #483042
            Ray Lyons
              @raylyons29267
              Sounds Good to me. Seen a few on YouTube which provide a decent workshop. There are a lot of new adhesives which can be used to fix the internal cladding.
              #483043
              Robert Atkinson 2
                @robertatkinson2
                I second Bo'sun's Comments. Plain ISO containers will literally generate their own climate including "rain" from condensation. You need to at least line it with wood and preferably insulation. A 20ft or two will be easier to handle and be moore practical, The extra end wall area means you waste less space for accesses. Fully stuffing a 40ft or 2x20ft gives the same volume, but if you have to alllow access to the contents 2x20ft work a lot better.
                Robert G8RPI.
                #483050
                Nicholas Farr
                  @nicholasfarr14254
                  Hi, I did have thoughts about this idea, but then I obtained an old disused quarry mess room for free. A workmate and myself had to go and fix a leaking side door that had been fitted to one of these containers in a storage yard, that was all nicely lined from floor to ceiling with wooden panelling, it was quite cosy inside and dry (apart from the leaking door, until we fixed it) if I remember right, they were storing a lot of cardboard goods in there. Of course there were no windows, so all lighting was artificial.
                  Regards Nick.
                  #483053
                  JA
                    @ja
                    The Army use, or used, containers for workshops. They may come up for sale in the military disposal market which now highly specialised.
                    JA
                    #483063
                    Journeyman
                      @journeyman
                      Containers Direct sell used and converted containers and have an interesting web-site.
                      I.M. OUTAHERE
                        @i-m-outahere
                        If you take a look at Bundy bears YouTube channel you might get a few ideas for setting up in a container , Lance did this recently he seems happy with it . I have been considering moving into something a little bit bigger than a car trailer but this would mean downsizing on a major scale and there are other drawbacks like the trailer has to rego’d then inspected every year as it would have mass of over 750 kg which is the maximum mass before brakes must be fitted – a yearly PIA i could do without !
                        #483070
                        Ady1
                          @ady1
                          Long time ago now, used to carry zillions of 'em
                          40 footers really for high volume low weight goods, very bendy at each end if lifted on a forklift
                          Load it evenly if a forklift is going to be used
                          40ft best option if you want a portable workshop in a tight long space with one entrance
                          you can rig up your own environment in a container because they are virtually airtight, a battery operated dehumidifier for instance
                          20 footers are for the heavy stuff and much stiffer/simpler
                          GL
                          Edited By Ady1 on 30/06/2020 09:17:38
                          #483073
                          Tony Martyr
                            @tonymartyr14488
                            Look for a second hand Site Cabin which are based on ISO containers. They already have the door, windows a power-cable inlet and security shutters fitted.
                            #483075
                            Ady1
                              @ady1
                              You can live in them, we used to say hi to a german chap in costa rica who lived in a 20 footer
                              He got drunk and missed his ship sailing so was spending 9 months doing odd jobs and waiting for it to come back
                              #483082
                              Spurry
                                @spurry
                                When I moved, I had a few containers from Portable Space in Stowmarket, so may be of use, depending where in the UK you are located. Excellent company to deal with.
                                Would confirm the condensation problems noted above, and highly recommend a decent concrete footing (one foot cube) where the units would normally bolt down. Without footings it is surprising how much the steel structure will bend…
                                Pete
                                #483085
                                Clive Foster
                                  @clivefoster55965
                                  Worst thing when working in a container is the ceiling height which I find oppressively low. If you are uncomfortable in it you won't use it.
                                  I wonder if lightweight add on roof and side cladding suitably spaced from the sides with the space ventilated might make a useful difference to the internal condensation issue. Tent fabric ought to do for a short term job. As I understand it the proper office / workshop conversions are a bit more sophisticated than simple linings. I have seen a similar conversion, lorry body in this case, with simple plywood lining that had rotted out after only a couple or four years. Basically a pond between lining and wall.
                                  The ex army workshop breed will be very expensive and well used. Generally they don't get sold off until the interior needs stripping out and re-doing. Despite decent windows I still wouldn't care to do standing up jobs in them. Sitting at a bench for electronics work was OK (ish) except for the pressure of getting failed trials equipment up and running without wasting expensive range time!
                                  Time for a lot of Googling for ideas on how / what to do and pitfalls / "I wish I'd" posts.
                                  If you aren't careful this could easily turn into an expensive cheap option where starting with something that looks as if it's going to be less costly ends up being both more expensive and not as good as doing it right. This was certainly the case with the two or three similar conversions, albeit lorry bodies not containers, that I have personal knowledge of. In both cases the costs and effort of all the detail bits that didn't get thought through exploded.
                                  I wonder how expensive and how practical it would be to make a timber shop built the way mine is easy to take apart and re-assemble. Mine is 2 x 4 framing with OSB panelling inside and out. Insulation between the panels and shiplap cladding outside. Insulation above the ceiling, floored loft – store and insulated steel sheet roof. In principle it ought to be possible to come up with a way to join the panels together without needing to get inside them. Perhaps something as simple as (stainless) steel strips and angle screwed on at the joints would work. Major Issue would seem to be pulling things up tight and square before fitting the strips.
                                  #483090
                                  Samsaranda
                                    @samsaranda
                                    We operated out of converted steel ISO containers and portakabins at RAF Stanley in the Falklands. The ISO containers were wood lined and had windows, they made good workshops, power was supplied by generating sets. The weather in the Falklands could be pretty severe and the containers withstood everything thrown at them, not aware of any problems with condensation but the wood lining prevented the moist air contacting the cold steel. I would have no reservations in using one for a home workshop although senior management would probably have serious objections on aesthetic grounds.
                                    Dave W
                                    #483104
                                    jann west
                                      @jannwest71382
                                      Interestingly ex UK MOD container workshops are available to purchase – perhaps the photo's might provide some inspiration:
                                      Bo’sun
                                        @bosun58570
                                        A good point raised. Check with your local authority about planning consent. We have several on our Scout Campsite and require planning consent. We're checked every few years to make sure we haven't sprouted any more.
                                        #483109
                                        Bob Worsley
                                          @bobworsley31976
                                          Try looking regularly on
                                          mod-sales.com
                                          in their auction. Often have the ex-military workshops, toilet blocks etc which have 2" foam insulation around them. Most are only 15' or so long, check. There are a few of the curved top type, but inside heght less than 6', don't buy unless you are shorter.
                                          I bought one of these years ago, got logburner in it and really comfy.
                                          I have used Worcestercontainers to move several of my lumpy bits, nice helpful people.
                                          #483118
                                          Samsaranda
                                            @samsaranda
                                            The workshops shown in Jann West’s link are far more sophisticated than those we had at RAF Stanley, I would certainly have one of those in my garden..
                                            Dave W
                                            #483120
                                            Alan Waddington 2
                                              @alanwaddington2
                                              Look for an insulated fridge container. No need to mess about lining it then.
                                              You can get a 40 footer with a roller door for around a grand plus vat and delivery.
                                              #483150
                                              Bazyle
                                                @bazyle
                                                We have a couple of 20 ft as stores at one club, spaced so we covered the gap with clear corrugated sheet for an outside shelter & tea area. Just one so far at the other club. All cost way more than a grand being patched and painted as you don't want one that is almost falling apart. Remember they have stopped being used for freight for a reason.
                                                Insulation just allows the condensation to hide and slowly rot or grow mushrooms behind the panel. Dehumidifier essential. When looking for a Men's shed we couldn't find any prefab or site buildings not falling apart for less than 4k. We buil equivalent of double garage in traditional 4×2 etc for about 10k. Yes wood has become bleedin' expensive not like it grows on trees.
                                                #483154
                                                Andy Carruthers
                                                  Wow thanks for all the great advice here
                                                  @Dave W – our paths crossed, I was at Mt Alice in 1988 and lived in ISOs whilst there
                                                  #483360
                                                  Samsaranda
                                                    @samsaranda
                                                    Andy
                                                    I was at Stanley Jan 85, left the Air Force in 86.
                                                    Dave W
                                                    #483367
                                                    Robert Atkinson 2
                                                      @robertatkinson2
                                                      Three comments
                                                      The proper military workshop and special purpose "containers" are built from scratch with insulated wall panels. Nice but can be expensive
                                                      You can get "one trip" used containers fairly cheaply as many countries export more than they import. I know if a plasterboard plant in Nevada re-opened and are shipping mot of their output to the far east at minimal costs s otherwise the ships would be in ballast.
                                                      If you get refriderated contaner the first thing to do is add at least some fixed ventillation as they are airtight to the point you could suffocate nd fumes etc can't escape.
                                                      Robert G8RPI.
