I'm really impressed that Mark C is able to routinely get into the blue blizzard regime with his Boxford. My old Heavy 10 could barely manage that under optimum conditions but, as might be expected, the Smart & Brown 1024 manages it with pretty contemptuous ease unless the insert book specifications are approaching insane for manual machines. Even with a reasonably effective chip guard the swarf is still a complete pain in the, well, pretty much everywhere and is why I've pretty much given up on inserts for routine work. When contemplating the benefits of full motorcycling gear; leathers, helmet an all; over the standard shop coat or overalls starts looking almost serious rather than distinctly facetious something has to give. So I've gone back to tool grinding, mostly.
Although blue blizzard AKA proper book regime pretty much guarantees good surface finish its not really appropriate to Model Engineer or Home Shop folk with machines at the bench and smaller end of the spectrum. Quite apart from the chip issue everything happens very fast, especially for neophytes, and full bore lifetime of ill chosen inserts can be distressingly short. With cutting edge cost starting at something of the order of £1 even the most awesome finish is a poor bargain for a couple of hours or less life in cut. Doesn't help that ME or HS guy frequently needs to scrape the odd few tenths or thou or so off which really isn't the sort of thing inserts are designed for. Well chosen ones can do it but its not part of the designers brief.
Given that it probably costs something between £50 and £150 from a standing start to have reasonable lathe tool and end of end mill touch up capabilities going insert only from day one looks quite viable from a financial perspective. In the end HSS Sharpening Man will probably spend less but if Insert Guy (or Gal) can be provided with suitable inserts having lifetimes of hours, hopefully 10 or more, in cut giving a good finish at comfortable speeds and cutting depths, right down to sub thou if need be, insert only seems perfectly viable way to work. As well as avoiding swarf embarrassment the chosen inserts need to be tolerant of interrupted cut and damage from inadvertent too fast / too heavy engagement with the workpiece. Buying a box of 10 insets with, say, 4 edges each and an anticipated life in cut approaching 10 hours for £20 off E-Bay is a good bargain until less than perfect skills chip a cutting edge after only a few minutes use. A theoretical 400 cutting hours or more for £20 to £30 is nice but thats only 400 edge destroying mistakes per box and I seriously doubt if anyone gets to a reasonable skill level without committing 100, or more, sins capable of destroying the edge of an ill chosen insert long before the end of its lifetime. With HSS edge damaging errors just mean a short walk to the grinder but every chipped edge on an insert is a chip out of the play budget. Which is always way too small to start with.
The various shape type suggestions mean little to a beginner. Shape really only defines what spaces the insert can get into. Although less edges per piece I'm inclined to consider the diamond style as being most appropriate as the one and only second turning insert purchase as being better able to get into the smaller spaces typical of much ME work. The first insert purchase should, of course, be a parting off type whose all round superiority to HSS is unquestioned. What the neophyte, and HSS switchers need, is decent advice on speeds, feeds, insert material and insert edge design style that will work well on their particular type of machine. I'd be unsurprised to find that there are hundreds of different, for example, CCMT inserts in sizes useable on ME machines. Probably a quarter to a half of which can be coaxed into good, or some semblance thereof, results by skilled folk. Maybe 5 to 10 percent being a pretty decent choice for a beginner in being reasonably robust and giving decent results over a fiscally acceptable lifetime using experienced ME advised speed, feed and depth of cut information. Maybe 1 or 2 percent will be real ME stars giving awesome finish over a long life in a variety of materials whist standing up well to the odd Boo-Boo.
Finding the stars will take a community effort.
Clive.
