Is it carbide?
Is it carbide?
Home Forums General Questions Is it carbide?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #227270
    Rainbows
      @rainbows
      I went out to my favourite second hand shops today and among the things I got in a bundle was a 20mm slot drill, 105mm long with a chip on each cutting corner. For a small piece of metal it feels rather heavy. Is there a way to tell whether an unmarked bit is HSS or carbide?
      Rainbows
        @rainbows
        #227276
        Tony Pratt 1
          @tonypratt1
          I don't think tooling grade tungsten carbide is magnetic?
          Tony
          #227277
          Les Jones 1
            @lesjones1
            I think measuring the density is the easiest method The density of tungsten carbide is 15.6 gm / cc. The density of HSS is 8.1 gm / cc. The easiest way to measure the density is by using Archimedes principle. Weigh the item on kitchen scales and make a note of the weight. Then put a container of water on the scales and zero the scales (Or note the reading.) suspend the item with a piece of cotton and immerse it in the water. It must be fully immersed but not touching the bottom. The increase in reading is the weight of water displaced. So as the density of water is 1 gm / cc the weiight of the item in air divided by the weight of water displaced is the density.
            Edit.
                    I just noticed Tony's answer. I also had that thought but on testing the carbide tip I had was magnetic but not  as much as HSS.
            Les.
            Edited By Les Jones 1 on 27/02/2016 17:39:47
            #227283
              If it's heavy and chipped rather than worn, I would say almost certainly carbide.
              Roderick Jenkins
                @roderickjenkins93242
                Posted by Tony Pratt 1 on 27/02/2016 17:35:27:
                Tungsten carbide is usually sintered using cobalt, which is magnetic, as a binder.
                Rod
                #227339
                John Fielding
                  @johnfielding34086
                  I just tried a few solid carbide printed circuit board drills on a big magnet. There are mildly magnetic but not as much as MS or HSS. An easy way to test is to try grinding them on a normal grinder. If they are carbide then the wheel will hardly do anything, but a green grit wheel should grind OK.
                  #227418
                  John Haine
                    @johnhaine32865
                    My immediate thought reading Les' suggestion was that it was wrong! Archimedes says the loss in weight of an object immersed in a fluid is equal to the weight of fluid displaced. I'd never thought about the weight of a container holding the fluid, but surely that wouldn't change? As I was just making breakfast in the kitchen it was a matter of but a moment to fill a mug with water, pop it on the digital scale, tare it, and stick my finger in. To my initial surprise the indicated weight increased! The reason why niggled all morning but came to me in the middle of treating some wood with Cuprinol. An interesting experiment, both actual and mental.
                    Edited By John Haine on 28/02/2016 13:45:58
                    #227421
                    Circlip
                      @circlip
                      That's cos you were pushing the water down. Try pulling yer fingy out quickly, It should show lighter than original.
                      Regards Ian.
                      #227422
                      Martin Connelly
                        @martinconnelly55370
                        If you have a spring scale you can weigh the bit when fully immersed and the difference between the immersed weight and the weight in air will give the weight of the displaced water. The air weight divided by the displaced water weight should give density.
                        Martin
                        #227453
                        mick
                          @mick65121
                          Put an unimportant bit against a white grinding wheel, if it glows red but doesn't grind away then its carbide.
                          #227456
                            Hold a modest metal weight, say about 4-6 ounces, on the palm of your hand. Now immerse hand and weight in water.
                            Does the weight feel lighter, heavier or the same?
                            Clive Hartland
                              @clivehartland94829
                              No, just wet!
                              #227491
                              Les Jones 1
                                @lesjones1
                                Hi John (H),
                                Did you leave the end of your post the way it is to prompt more discussion on the subject ?
                                Les.
                                #227496
                                John Haine
                                  @johnhaine32865
                                  Les, indeed I did! I looked up Archimedes Principle on Wikipedia and like everything else I've read it explained it in terms of the reduction in weight of the suspended object. I'd never seen the version you quoted and at first it seemed unlikely, but experiment doesn't lie.
