There have been a number of posts arising from members having difficulty with Inverter / Variable Frequency Drives.
These devices have a number of characteristics which can trap the unwary and it would be helpful for these to be explored and pulled together in one place, hopefully in terms that can be easily understood by less technically informed members of our community.
This might already be met by reference to a book or learned paper with which I for one am unfamiliar!
To set the ball rolling I list below some of the issues that I think worthy of highlighting:
1. Safety
a. nature of their output and requirements of cabling and earth bonding.
b. Power stored in the drive (power capacitors) and residual power after mains power is lost. How to ensure it is powered down before diving into the electrics.
c. Effect of using conventional 'No Volts release' starters with inverter drives – damage to capacitors, how to prevent machines from self restarting after power loss, how to wire in emergency stop switches.
d. Fire risks and fires from failing power capacitors. Non combustible mounting boards, dust free ventilation and distance from combustible surfaces.
e. Separation of power and extra low voltage (signal / control) wiring.
2. Compliance with Building Regulations, IEE Regs and insurers requirements.
a. Fixed wiring or plugged connections.
b. RCD protection and associated issues
c. testing and certification
3. Practical Application to Machine Motors
a. Appropriate motors and how to identify them.
b. Use of one drive to feed more than one machine (or not)
c. Use of multiple motors on one machine (eg suds pumps and power feed drives) operating at different rotational speeds.
d. Star or Delta configuration and what inverters will work with them.
e. How to control overheating of motors (ability to 'self cool' when revs are reduced, loss of torque if voltage is reduced at lower frequencies) Reliable rules of thumb.
f. How to establish and input control and protective settings appropriate to you motor/ machine setup
g. How to control speed at either the inverter or with remote controller (potentiometer)
h. Selection ( electrical, mechanical characteristics, 'suds proofing'
and mounting speed control potentiometer on your machine. Suitable plug and socket connectors for ELV wiring.
i. How to use one inverter to feed more than one machine (or not)
j. How to establish safe 'overspeed' of your motor / machine by setting frequencies above 50 Hz. Appropriate rules of thumb. (Chuck explosion, grinding wheel failure, lubrication / bearing failure)
k. Appropriate acceleration and deceleration settings, electric braking and switching between forward and reverse.
l. Trouble shooting, Fault codes and how to address their cause.
m. Sources of inverters and pitfalls.
n. Need to reform capacitors and how to do this (when inverters have been unused for 2 or more years). Implications of not doing this.
