The disc is to calibrate the inside micrometer in case the measure is out of order. Insert the disc into the two ended spanner and turn the micrometer carefully and check there is 5 mm. In case not 5 mm, adjust with the spanner carefully until it showing 5 mm and reread again under calibrating, when the micrometer is correct at 5 mm each time. Ready to use.
Important! The room temperature must be 20 degree celsius (68 Fahrenheit) to get right reading of measure results is correct while you are calibrating the micrometer. Keep micrometer clean and free from swarf,dust. Do not leave the micrometer on the machines or places where it generates heat and you get the error measure of micrometer. Do not measure while the subject is hot. Let it lie in their own storage box that came with the micrometer.
