Posted by Clive Foster on 29/07/2020 19:10:27:
Are they sufficiently repeatable for reliable case hardening and what size would I need to handle the 2" long, 1/4" diameter pins. I'm thinking the nominal 1000 W or thereabouts jobbies would be about right.
Standard coils look to be too fat and short for my job. Presumably I can wind a longer, thinner one from copper tube. I have some copper brake tube in stock (supplied wrongly when I ordered Kunifer so need to use it for something else less critical).
Are they capable of surface hardening a steel such as 708M40 (EN19) if used for an appropriate time before oil quenching? Obviously I'd need to start with annealed material first. Which may be an issue.
Clive, most of those heaters available 'cheaply' are a Royer oscillator type – they work quite well. One downside is that the output power on those units depends solely on the input voltage – the 500watt or so units are typically 12 to 15 volts, and the 1-2KW seem to work from 30 to 50 volts . Including losses in both the heater and the power supply, you would need a supply of around 40 to 50 volts at 25 amps or more…
The pins you describe , with a long thin induction coil, would take 30 to 40 sec to get to red heat with a 1KW unit.
The second issue is that even for a 500 watt unit, you will need to water cool the induction coil. Also, the coil must be made from good quality copper as least – not copper plated steel brake piping..
The coil gets VERY hot – in the KW unit there are many hundreds of amps flowing in the coil ( its part of a resonant circuit) and due to the high frequency, the current flows mainly close to the surface of the coil. This means the resistance is higher so the losses are big.
However….I do not think these simple heaters will work for you – they will not be able to case harden as the frequency they work at is too low.
For a ferrous steel ( as opposed to non-magnetic stainless steel, for example) the depth of penetration of eddy currents is very dependant on the frequency of said current. Typically, frequencies of 20KHz to 60KHz are used and this results in full almost full penetration of eddy currents in a steel bar of 25mm diameter. That means that the material will heat up evenly, all the way through. Quenching that will give a fully through hardened work piece.
The higher the frequency, the less the depth of penetration. The workpiece then heats up close to the surface, where the eddy current concentrates, and that heat is then conducted ( more slowly) through the work piece.
This would then harden the outside when quenched. The frequencies typical for this method are from 200KHz, all the way up to 13MHz – the MHz ranges are often used for non-ferrous metals, copper, aluminium, etc, in small workpiece volumes.
A second However, is needed…If the heater ( assuming an appropriate frequency) has to low a power capability, the rate of heating the workpiece surface could be too slow, and be the same as the rate at which the heat is conducted from the surface to the inner core of the workpiece. So, the whole workpiece gets hot through again…
I suspect that for 6mm pins you would need a 2 to 4 KW unit, to get the outer casing red hot, with the inner approaching but not reaching annealing temp – that would probably need to be done in less than 6 to 8 seconds…
Joe
EDIT – those common Royer type induction heaters are typically 30KHz to 50KHz – they are not fixed and change frequency depending on the coil's inductance and whats in the coil to be heated.
Edited By Joseph Noci 1 on 29/07/2020 21:08:54
