Posted by Speedy Builder5 on 18/05/2021 14:21:20:
how will the electricity be made to produce the hydrogen in the first place? Would the cost to the planet of making renewables outweigh the advantages of clean hydrogen appliances ??
Could we get to the state where we are oxygen depleted as we start to turn it all back into water again ?
Will we be in a continuous fog of mist ?
Hydrogen is easily made by electrolysing water. As the other product is Oxygen, burning electrolytic Hydrogen doesn't deplete Oxygen. Energy from the sun is free. Once solar panels have set up the electricity they produce is much cheaper than coal. Relative costs of Coal vs Solar:
____________ Coal ______ Solar
Set-up $2900/kW ____ $3700/kW : 20% cheaper to build a Coal Power Station
Running Cost $33/MWhr $8/MWhr : Solar electricity at least 75% cheaper than coal
The cost of solar electricity is set to drop as panel technology improves.
The big advantage of coal is power stations can respond to changing demand at any time. The main disadvantage of Solar is it only generates during daytime good weather, when demand could be low. Unfortunately, although solar produces dirt cheap electricity, it's likely to be at the wrong time
What's needed is a way of storing or usefully consuming excess solar electricity. One option is to make Hydrogen from it, and then burn the Hydrogen to heat homes, run hybrid cars, or fuel cells. Low prices will attract other users to off-peak energy, such as charging parked electric cars.
Traditionalists know it's far too expensive to make Hydrogen from coal generated electricity and might assume the same rules apply to solar. They don't! It's economic to make Hydrogen with surplus solar energy with the added advantage burning Hydrogen is almost pollution free. Burning petrol creates a lot of water too: the watery part of car exhaust isn't a problem, mist or otherwise.
Hydrogen is difficult stuff to handle: I'd expect it to be diluted rather than used pure in a home heating system. That's not new though – UK coal gas was 50% Hydrogen calmed down with Methane, Carbon Monoxide and Ethylene. What could possibly go wrong!
Edited By SillyOldDuffer on 18/05/2021 15:42:51
