Morning all
As part of my ongoing restoration of a Wilfin lathe I'm trying to get a nice smooth finish on all painted parts.
First part to be painted was the drip tray which the process was
Bend bent parts back to shape
Weld up crack on rim, grind smooth
Flap disc entire surface
Body filler entire surface (the tray looked like a moonscape of little pits)
Flap disc entire surface smooth
Screwfix basics red oxide primer, 2 coats, sand between coats
Machinery enamel. BS 00 A 09 Mid Gray, Gloss
Paint, sand, paint again (and a few more times trying to get a flat finish)
Now the issue is, if I paint thinly I get brush strokes left in the paint surface, if I paint thick the brush marks level out but I get left with splotches where some paint is obviously thicker than other parts.
I looked at my mini lathe and they have done a pretty good job of getting a perfectly flat finish with some no doubt cheap labour. Can anyone see the part of my process that is giving me such uneven fninishes?
