I recently had a spindle made from my Wizard lathe by a well known Stevenson (thanks again). My old spindle would slip into the pulley with no friction and needed a grubscrew to keep it roating on the shaft. The new spindle is a fairly tight intereference fit with the pulley where to get the spindle to go in by any amount requires a medium hammer. After some time considering the options I decided I would want a looser fit and to modify the pulley rather than the spindle.
Anyone got a method for enlarging the hole by a tiny amount to get a slip fit while keeping everything concentric?
I think you need to think again about the problem before removing any metal. Firstly what are the diameters involved (and can you measure them accurately). From your description the spindle may have been manufactured oversize (reject it as out of specification, 'not fit for purpose' etc )
An adjustable reamer would probably be the best way of opening the pulley bore. As long as you have some way of keeping it square and concentric the bore could be enlarged in minute increments to get the fit you want.
If the pulley has a machined flat face, sit it on the drilling machine with reamer in chuck at slow speed (or turn by hand). The reamer will keep pretty concentric and if you turn the pulley a quarter of a turn every few revs of the reamer it will compensate for any tilt of the table.
Problem with flex hones in a case like this is the pulley is only 1/2" diameter bore and probably the same depth and those hones just want to expand at both ends and you finish up with a trumpet shaped bore.
Bit of wet and dry or even emery on a split dowel will have done this in less time than it took to write this.
Flex Hones design will not produce a cone as the constant movement through the hole and the design of the hone prevents it. Any diameter/length ratios are permissible.
I would probably use an expanding reamer remembering that they usually have a bit of a mind of their own.
In some ways it might be best to expand in the bore well past any lead in the reamer may have for a rather light interference fit rather than trying to open up until a light cut is taken.
Edited By Ajohnw on 12/02/2016 16:19:29
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
