Posted by pgk pgk on 10/08/2022 12:25:20:
Posted by Hopper on 10/08/2022 11:59:00:
Posted by pgk pgk on 10/08/2022 11:48:41:
UK coal reserves depend on which document you read and on relative accessibility…
The site you link to bills itself as "The Voice of Coal in Europe" so is not an unbiased source.
The source Dave (SOD) linked to, Worldometer, is an unbiased stat site in my experience.
Worldometer usually take their figures from government publications and very much dependant on how those figures were arrived at. Agree the link I used is biased and will include uneconomic sources…but they are only uneconomic at today's price. I see no reason to doubt the underlying geology….
Interesting to see such different numbers. I suspect Worldometer are reporting recoverable coal and Voice of Coal are reporting all coal, whether recoverable or not.
For example, Voice of Coal report 1 billion tons in Northern Ireland, about 20% of the UK total. Other surveys suggest 600 million tons but everyone agrees It's Lignite. Lignite or 'brown coal' is the lowest form of coal. It's up to 30% carbon and wet, completely useless for running steam engines or steel-making. But it could be burned in a coal power station built on top of a large strip mine. No-one in Northern Ireland wants it. Not an easy win for coal, and I suspect the deposit isn't considered 'recoverable' for policy reasons.
Thin seams deep underground are another reason UK coal isn't recoverable. The Durham Mining Museum has lots of information about coal mining in the North of England, including details of coal seams detected by shafts. Picked at random, the Elemore Colliery was about 5 miles from Durham. Opened in 1825, main seam exhausted in 1892, became part of a larger complex for drainage and ventilation until the group closed in 1972. 165 known deaths.
The coal:
- At 67metres deep, a 0.7m of coarse slaty coal. 0.53m of coal at 69m & 0.58m at 70m
- Seam 0.15m thick at 72m
- 0.38m seam at 94m & 0.36m at 108m
- 125m down is 1.83m of coal three thick seams, separated by only 0.56m of rubbish
- At 149m, a seam 0.18m thick
- And at 172.2 metres. another layer of profitable coal – 1.73m
How much is left? Depends on the value of coal versus the cost of recovery, but the outlook in this example is grim. I suspect the top 3 seams were extracted in the early 19th century because 1.82m of coal was mixed with only 0.86m of muck.
The thin 0.15m layer is likely intact because mining it requires huge amount of waste to be removed. The economics are still poor: would anyone today dig a 72 metre shaft in order to exploit a coal seam only 0.17m thick? Possibly in future, but only if coal becomes massively more expensive.
The 0.36 and 0.38m seams are marginal. I suspect they're still there because getting the coal out when the mine was operating meant a lot muck had to be removed with it. Not much return for a lot of work. Today, the economics of a 100m deep shaft to reach two thin seams are poor.
The thin seam at 149m is almost certainly untouched, but retrieving it would be seriously expensive. Too much rubbish has to be lifted out for not much coal.
Quite a lot of the two big seams may still be available. Early miners used the pillar & stall method. Even though the pillars were aggressively thinned out as the mine reached end of life, a lot of coal is left behind – it holds up the roof! If old galleries are close to the surface, it's possible now to get the coal by strip mining – modern earth moving equipment is very capable. But strip mining gets gets more damaging to the surface and expensive with depth. Digging out a 172m deep strip mine might be viable in the wilds of Australia, but the Durham area is heavily populated! (Southerners won't care if County Durham and most of Yorkshire are strip mined, but locals will make a silly fuss.)
Later the longwall method was used. Almost all the coal is removed, so what's left isn't worth reworking. There are no pillars. Instead the roof is carefully collapsed behind the working face as it moves forward.
Whichever method was used the ground is left badly weakened and full of water filled voids. They are extremely dangerous to approach with new tunnels seeking untouched coal, and the cost severely limits what's practically recoverable.
This website shows most UK coal mines dug in modern times. There are a lot them! As our forefathers did a good job removing all the coal they could, knew where to dig, and thoroughly churned up the ground, there isn't a massive amount of easily extracted coal left in the UK. I think Voice of Coal are glossing over that in order to encourage investment. There is coal, but not as much as they suggest.
Energy can be recovered from thin seams by setting fire to them and allowing only enough air for a smoulder. Pumped out and cleaned up the resulting gases is rather like original Town Gas. Unfortunately even keen coal fan-boys become NIMBYs on finding their house is to have burning coal underneath!
Edited By SillyOldDuffer on 11/08/2022 19:08:59
