How many rings per piston?
Home Forums Locomotives How many rings per piston?
Viewing 25 posts - 1 through 25 (of 38 total)
  • #797187
    Arthur Jones 2
      @arthurjones2
      Hi all,
      I’m building a 3 1/2″ gauge “William” 2-6-2T (Martin Evans) but rather than use gunmetal cast cylinders I’ve machined the cylinders from Meehanite blocks – not least because I’m still learning and did not want to waste money if I scrapped one or more!  I realise that 3 1/2″ gauge is at the bottom end of usual size for CI cylinders and that I’ll need to be very diligent about draining and oiling after runs.  I’ve nearly finished the cylinders now, just the mounting holes to drill and tap and the valve faces to finish-machine.  Steam chests, cylinder end covers etc. are similarly just about made, just the chest covers, valves and pistons still to make.
      I am planning to use piston rings (rather than O-rings, packing etc.) and wonder whether one or two are required per cylinder.  The cylinders are 1 1/8″ bore and I have managed to get both of them more or less dead size (something like +- 0.0005″).  They are now honed.  I am proposing to buy the rings ready made from Reeves (yes, I know that making them isn’t terribly difficult but I am balancing time spent vs. cost, and time spent may be more valuable at the moment as I’m extremely busy!).
      My question is: will one piston ring per piston be adequate or are two needed?  I’m tempted to go with one but realise that more are typically used on IC engines and full size locos.
      Any advice would be appreciated!
      Kind regards
      Arthur
      Brian Baker 2
        @brianbaker2
        Greetings Arthur, you seem to be making good progress, well done.
        I think cylinders machined from Meehanite is the way to go, and intend doing that on my next build.
        As you are using plain rings, I would be inclined to use two per piston, they could go in the same slot, but better if you can to separate them and make sure the ring gaps are 180 degrees apart, ie opposite.
        Brian B
        #797195
        duncan webster 1
          @duncanwebster1
          Commercial piston rings tend to be a lot wider than need be, and hence cause more friction. Reeves won’t let me into their site unless I accept cookies, so I won’t be going there. I made the rings for on of my locos, 0.045″ square and 1.5″ diameter. I had access to a heat treatment furnace. As Brian says, 2 grooves better, one of the leak paths is underneath the ring, it’s a lot more tortuous with 2 rings in 2 grooves
          #797217
          Clive Brown 1
            @clivebrown1
            My Simplex has 2 x 1/8″ wide rings and seems to work well. The rings are from Reeves. The shorter piston of “William” with two similar rings might make the lands between the grooves rather narrow. I suspect one ring would be OK. It’s more important to get a good fit between the piston and bore.
            After running and blow-down I always inject a goodly squirt of oil into the cylinders through the four draincocks, using a hypodermic syringe.
            #797218
              Two on a steam piston.   In full-size often pinned so the gaps can’t rotate into alignment.
              Trivia corner, they’re called Ramsbottom Rings after their classy Victorian inventor .
              Tim Stevens
                @timstevens64731
                It might help you to know how piston rings actually work. This can help at the machining stage so you can concentrate on getting the sealing surfaces smooth – as long as you know which sides of what does the sealing.
                What follows is based in ICE practice, but there are really only two differences between petrol and steam, in piston ring terms: The ICE piston works with pressure always on the same side as the sparking plug. Steam is more normally used on both sides alternately (and without any ‘gaps’ in the flow of power). What happens is this: The pressurised gas goes down between the cylinder head and the piston until it gets to the ring, which it pushes against the bottom of the groove. The pressure then can get behind the ring and acts to force the ring outwards against the cylinder wall. So, the rings rely for sealing on good continuous smooth surfaces on the lower face of the ring and the lowest face of the ring groove. On the way back up in a steam engine, the same process happens, relying on the fit of the opposite face of the ring and the opposite face of the ring groove. And it doesn’t seem to improve matters if you use a complex joint where the two ends of the ring meet up – but it does help to reduce the ring gap in the fitted condition as much as you can, on first build.
                Petrol and diesel engines often have some identification etched or marked on their rings, and if you follow the pressure faces argument as described above, you will see why these marks are always on the top surface of the ring (as they are marked on a non-sealing surface). Both sides are critical for double acting (steam) engines, so both sides of the ring and its groove must be as near dead flat and smooth as you can get them.
                The proper name of piston rings – just in case anyone else is interested in such details – is Ramsbottom’s Metallic Packing. John Ramsbottom was Chief Engineer of the Manchester & Birmingham Railway, later forming part of the LNWR, and he also invented tamper-proof safety valves and the most wonderful invention for small boys, the water trough between the rails so the speeding train could force water into the boiler at speed, and drench anyone who happened to be looking out of the windows. How do I know?
                Tim Stevens
                #797226
                Nigel Graham 2
                  @nigelgraham2
                  Tim –
                  ….. the water trough between the rails so the speeding train could force water into the boiler at speed, …
                  Not the boiler. The water scooped from the troughs went into the tender. The injectors fed the boiler, from the tender.
                  #797228
                  noel shelley
                    @noelshelley55608
                    Thank you Nigel, you beat me to it ! Noel.
                    #797230
                    Nigel Graham 2
                      @nigelgraham2
                      I had problems logging-in then accidentally logged out so I apologise if this appears twice.
                      Tim –
                      … the water trough between the rails so the speeding train could force water into the boiler at speed,…
                      Errr, I think you mean the scooped-up water feeds the tender. The boiler is fed by the injectors, from the tender.
                      #797268
                      Arthur Jones 2
                        @arthurjones2
                        Hi all,
                        Thanks for your replies – very much appreciated.  The Reeves rings I was thinking of are 1 1/8″ x 1/16″ so just a bit wider than the 0.045″ rings suggested by Duncan, but certainly narrow enough to fit two of them into a 1/2″ wide piston (three lands each 1/8″ wide with 1/16″ grooves in between).  The put-off might be the cost of four of them at £11 each plus postage, plus perhaps a spare or two given that I’ve never fitted rings before (sheltered youth, I guess).
                        I might have a go at making my own – I was hoping to avoid that.
                        Point taken about fit of piston in bore – but I also thought that some play was needed to avoid seizing during warm-up.  The school I was very fortunate to attend had a loco built by the pupils (unthinkable these days) which is still going strong 50+ years later (in the hands of another ex-pupil!) after much remedial maintenance.  The story goes that the piston ended up having to be machined down by quite a lot as it kept seizing when hot.  That piston is aluminium and the rings are/were motorbike rings.  I was going to use stainless steel for the piston (probably 316, not sure of exact grade as it’s unmarked) just to try to cut down on risk of rust buildup.  Its expansion is a bit more than for CI but not as much as aluminium.  I could make it of CI as I have some (limited) stock also. Any thoughts?
                        Kind regards to all and thanks again
                        Arthur
                        #797274
                        Charles Lamont
                          @charleslamont71117
                          A cast iron piston will be fine, with a normal running fit. And much easier to machine than stainless.
                          #797276
                          bernard towers
                            @bernardtowers37738
                            If you make your own you can make them with a thinner wall therfore lowering the wall pressure and friction. Plus it adds to your skills which is what this is all about isnt it?
                            #797278
                            Clive Brown 1
                              @clivebrown1
                              I’d also stick with cast iron for pistons. Rings undoubtedly have advantages, especially for a loco that is intended for a lot of use but there are thousands of successful models made with just soft packing. Piston / cylinder sealing is far more important for an ic engine, which won’t run at all unless it has good compression. Model steam engines are rather more tolerant.
                              #797288
                                Agree, and I suggest making a piston from an unknown Stainless Steel is positively asking for trouble.   There any many different stainless steels, many of them tricky to machine.  Worse, stainless steels are prone to gall, making them a particularly poor choice as a bearing material.    Stainless resists corrosion, but apart from that, it’s risky material in this application.
                                ChrisLH
                                  @chrislh
                                  Arthur. If you decide to make your own rings, I would recommend perusing an article by the once well known professor Denis Chaddock. It actually refers to construction of a 5cc IC engine but covers design and manufacture of the required piston rings. It’s all very practical and does not require a degree in anything at all to understand it. Please PM me if you would like a copy.
                                  #797523
                                  Arthur Jones 2
                                    @arthurjones2
                                    Thanks again everyone for the advice.  Charles, Bernard, Clive and Dave: making the pistons out of SS is clearly not such a good idea as I’d imagined!  I’ll make them from CI once I have the piston rings sorted out.
                                    Knowing what to make and what to buy in is always a bit of a balancing act – for example I’ve bought in the axle pump because it was not much more expensive than the castings!
                                    On reflection I’ll have a go at the rings – as Bernard says, it’s a chance to learn.  Thanks ChrisLH for the advice on Prof Chaddock’s article.  I think this must be 21-Apr 1967 vol. 133 issue 3,319 p. 396.  I don’t have a copy of this and I’m not going to the club this week (clash with something else) so if it’s OK Chris I’ll PM you regarding that.  I do remember another article in the mid 70s that gave detailed instructions (but I don’t think involved lapping or finishing the OD) but am struggling to identify it.
                                    Kind regards and thanks everyone again
                                    Arthur
                                    #797526
                                    duncan webster 1
                                      @duncanwebster1
                                      Also have a look at Tubal Cains articles (the English one, not that American imposter)). Chaddock was doing rings for IC engines, TC allows for steam. When I get home I’ll try to dig out the reference
                                      #797536
                                      Howard Lewis
                                        @howardlewis46836
                                        It is important that the surface finish of the side faces  of the rings and of the ring grooves, is good.
                                        A poor finish, and excessive clearance, will act as a leak path.
                                        I C engines often use gas backed rings where cylinder pressure increases the wall pressure.
                                        This improves sealing, and decreases friction when the piston is off load. Which is important in a four stroke engine, but less so in a steam engine, where the piston is likely to be loaded for both directions of travel for a double acting engine, such as a loco.
                                        The ring gap should be as small as is safe. (If the ring ends butt, breakage  and bore damage is likely).
                                        In an IC engine, minimal ring gaps (cold which will close up at running temperatures) reduce blowby, which is a loss of gas pressure that could be put to better use above the piston. Since pressures are lower in a steam engine, reduction of leakage becomes more important.
                                        #797588
                                        John Purdy
                                          @johnpurdy78347
                                          Arthur
                                          Besides Chaddock’s original article there some others that I have noted over the years that detail making piston rings.
                                          ME Apr. ’67 Chaddock’s article
                                          ME 5 OCT. ’73 Manson
                                          ME 2 Jul. ’76 Chaddoch’s reply to Manson
                                          EIM Oct ’79 John M. Tulloch
                                          ME 17 Aug. ’84 G. Trimble
                                          ME 21 Jan. ’94 Tubal Cain (a whole series)
                                          ME 23 Jul. ’04 snippet of an article not sure of the author
                                          ME 24 Apr ’09 Alan Beasley
                                          ME 22 Feb ’13 John Dickinson
                                          ME 27 Nov. ’15 Ben Crowdy
                                          ME 20 Oct. ’23 Martin Gearing
                                          These are what I have in my file and I have used the info to make rings with complete success. Hope this is some help.
                                          duncan webster 1
                                            @duncanwebster1
                                            TCs information is also in his Model Enginners Handbook
                                            #803064
                                            Arthur Jones 1
                                              @arthurjones1
                                              Hi all,
                                              Thanks for all your advice just over a month ago on making piston rings for my loco (William), and especially for the article by Prof. Chaddock (thanks ChrisLH!).  It has all been very useful and (on the face of it) easy to follow the Prof’s recipe.
                                              Sorry for the lack of updates.  The sticking point was obtaining the steel stock for making the clamping plates and machining jig specified by Prof. Chaddock – my usual supply of steel stock has now banned little people like me from buying from them.  Anyway, a local one-man engineering firm has obliged, to our mutual benefit, and I’ve been able to crack on with the job.
                                              I have now made five rings (1.124″ OD x 0.029″ wide x 0.031″ radial thickness) according to the Prof’s recipe (plus a few scrap and broken!).  I think I need four so I have one spare so far, and have unbroken ring “blanks” for another six.  But I have a few questions before finishing more rings or making the pistons.  Sorry for the length of the posting!
                                              1. I have followed the “recipe” and used a “gag” or wedge around 4 times the radial thickness which is 0.031 x 4 = 0.124″ (actually a sliver of 1/8″ gauge plate) for freezing the gap.  This gives an actual gap after freezing of marginally less than 0.125″, maybe 0.115″.  But after skimming the OD in a jig roughly to the Prof’s design, the gap closes up somewhat.  I now have four finished rings with gaps of around 3/32″ (0.093″) and one with a gap of around 1/16″ when not fitted!  I guess this is due to the tool peening/burnishing the outer surface and creating sufficient compressive stress on the outer surface to cause slight distortion.  This happened whether I used a carbide tip (CCMT) or a custom (and very sharp) HSS tool.  Is this normal?  Does it matter?
                                              2.  Next job is to make the pistons – fortunately I have just enough Meehanite left over from the rings if I am ingenious about holding it.  From earlier comments I think the suggestion is to use two rings per piston, both in the same groove and with the gaps diametrically opposed.  But that begs three questions: what sort of fit in the cylinder – someone said a “normal running fit”, and someone else said “a good fit” so presumably a sliding fit with negligible slack but no hint of interference?  How much side clearance for the pair of rings (a couple of thou, perhaps)?  And how much radial clearance (15 thou deeper than the rings, perhaps)? What do you think?
                                              3. After slightly cleaning up the snapped ends so the rings will just fit into the +0.002 sleeve in the Prof’s jig, and after skimming the outsides of the rings in the jig (in some cases having to machine maybe half a thou below the cylinder ID to clean up all the periphery of the ring), there is a gap of around 0.002-0.003″ in some of the rings, possibly even 0.004″, when tried in the cylinder bore.  Is this OK?  The bore is nominally 1.125″ – I’ve seen various recommendations for gaps but they seem to be 0.001″ per inch of bore, or possibly 0.001″ + 0.001″ per inch etc.
                                              4.  When it comes to fitting the rings, I’m ashamed to say I’ve never changed rings on an engine (sheltered life!).  Do I “wind” or feed them in, spiral-wise, starting with one end in the groove, in which case the ring will need to be twisted to offset one end from the rest by a quarter of an inch and which may put a permanent twist in it?  Or do I open them out enough (like opening a circlip) to slide them over the piston from the end, and risk permanently distorting the circular shape I’ve carefully finish-machined?  My fear is that I can’t win…and I don’t want to risk wasting my ring-making efforts on trial and error without seeking advice first!
                                              Sorry again for this rambling list of questions – I hope someone is patient enough to let me have some thoughts!
                                              Kind regards and many thanks in advance
                                              Arthur
                                              #803073
                                              duncan webster 1
                                                @duncanwebster1
                                                You need several sets of hands to fit rings. What I do is cut narrow strips off a beer can (other beverages might be available). These go longways spread around the piston to stop the ring getting into the groove until you’ve got it all expanded over the piston. Then slide the ring down level with the groove and pull the strips out one by one
                                                #803080
                                                Arthur Jones 1
                                                  @arthurjones1
                                                  Thanks Duncan.  Sounds ingenious, and I’d not have thought of that.  Just to be clear, is this approach necessary when (as in my case) no grooves have to be crossed before getting to the correct one, as there are only two rings and the piston can be ringed from either side?  Or is the plan to avoid the ring twisting etc. as it drops into its correct groove?
                                                  Any thoughts on the other points, anyone?
                                                  Any input greatly appreciated!
                                                  Arthur
                                                  PS I’m glad you said “other beverages are available” as I’m teetotal!
                                                  #803089
                                                  duncan webster 1
                                                    @duncanwebster1
                                                    Missed that you only have one groove, probably not necessary.
                                                    #803101
                                                      Do a web search for Piston Ring Tool.   It will reveal various devices for squeezing and manoeuvring rings into position, and then getting the piston into the cylinder.   A source of ideas rather than buying one, though maybe a plier?
                                                      Ignore those fears, and give it a try!   An ounce of practice is worth a pound of theory.
                                                    Home Forums Locomotives Topics
