Possibly, the seal between inner and outer has failed, so that it is no longer a vacuum flask, just having air as insulation between the vessels.
It is probably unrealistic to expect a metal vacuum flask to have a thermal performance equal to that of a silvered glass one.
The mass of metal of the inner vessel is probably greater, and is unlikely to be silvered like the glass ones, so heat will not be reflected back into the liquid contents..
Plus unless the metal inner vessel is insulated form the outer, as it is in the silvered glass vaccuum flask, heat will be conducted away, degrading performance.
FOR They don't break when dropped. Probably cheaper and easier to make.
AGAINST Less efficient.
We pay our money, and make our choice.
Edited By Howard Lewis on 09/11/2020 11:03:35
