Posted by Martin W on 19/04/2016 13:20:56:
So far I am quite happy that the upgrade happened and have not had any problems, it would appear to be as stable as W7 and faster on boot up not that W7 was particularly slow.
Martin
Hi Martin,
For many people the issue isn't that W10 is unstable, it is the privacy issues it introduces. There's plenty on the web about these concerns, this article for example.
It is not made obvious or easy during installation how to turn the privacy leaks off, or even that W10 is going to share some of your information and facilities unless you explicitly tell it not to.
After installing W10 I spent a lot of time wading through various settings undoing the damage. That's because I thought the default settings were unacceptable, particularly as the upgrade deliberately contravened some of my W7 security settings. You may not share my concerns, but if what I'm saying is news to you it might be advantageous to do more research before making your mind up.
This article seems to cover the ground if you want to know what to switch off.
Edited By SillyOldDuffer on 19/04/2016 21:18:59
Edited By SillyOldDuffer on 19/04/2016 21:20:06
