Hoglet V Twin Con Rod Casting
Home Forums General Questions Hoglet V Twin Con Rod Casting
  • #24532
    David Cambridge
      @davidcambridge45658
      David Cambridge
        I’ve been thinking about building the Hoglet V Twin and I am very much enjoying the current build thread.
        With my recent venture into casting I thought I’d try a few experiments with 3D printing to see if I could make a pattern for the Hoglet con rod, and then cast it in aluminium. This is just a prototype to see if it could work – a bit of fine tuning of the pattern is needed and the machining was rough and ready. But, none the less it shows promise!
        David
        Edited By David Cambridge on 08/05/2016 14:08:20
        #237949
          Nice looking casting but watch which aluminium you use to cast it from, it should be 2014 (HE15) but that is a tempered alloy so you may not get the strength and wear qualities if you just melt raw stock
          Edited By JasonB on 08/05/2016 16:11:13
