Help pls what lathe is this
Home Forums Manual machine tools Help pls what lathe is this
  • #456355
    julian lambert
      @julianlambert17802
      20200225_175427.jpg20200225_174458.jpgHi i have purchased a stedall lathe from a friend and i am trying to find a manual for it or even info on it.
      I have spent hours looking through photos and sites to see if i can find something similar to it but i cant so any help would be grateful. Thanks….
      Edited By JasonB on 09/03/2020 20:48:55
      julian lambert
        @julianlambert17802
        I can’t find any info on this.
        #456361
        Martin Connelly
          @martinconnelly55370
          As usual the starting point is lathes.co.uk Stedall
          Martin C
          #456365
          julian lambert
            @julianlambert17802
            Ive looked at that site and cant see any lathes that look the same.
            Its a good read though .
            #456367
            Martin Connelly
              It says they copied Lorch lathes. See Lorch Type AVI-K/AVII-K. Lorch
              Martin C
              #456374
              Bazyle
                @bazyle
                If you know for certain it is a Steadall take some high quality photos and provide them to Tony of the Lathes site wo he can include them for the record..
                #456395
                Pete Rimmer
                  @peterimmer30576
                  Looks like a typical Stedall layout except it appears to have a belt cover and a gap bed. Is the motor in the base?
                  #456396
                  julian lambert
                    @julianlambert17802
                    #456398
                    Speedy Builder5
                      @speedybuilder5
                      Is it a STEDALL ? The plate says Supplied by STEDALL. Have a good look at the tailstock end of the bed and see if you can see any other identification.
                      #456399
                        Posted by Speedy Builder5 on 10/03/2020 06:53:09:
                        yes The text on the previously-linked lathes.co.uk is quite helpful in that regard.
                        … and the mention of Manchester, on that plate, should assist with dating it.
                        Edit: Here’s another variation on the theme:
                        https://www.the-saleroom.com/en-gb/auction-catalogues/brighton-general-auctions/catalogue-id-srbrig10086/lot-6fa2e0b6-c9a4-4227-8e58-a84200cbf513
                        Edited By Michael Gilligan on 10/03/2020 07:43:05
                        #456411
                        julian lambert
                          @julianlambert17802
                          Hi again I'm away till Friday working but will look as soon as I get home I have started to strip it to repaint and rewire it with a few more safety features on it.
                          #456413
                          julian lambert
                            @julianlambert17802
                            #456414
                            julian lambert
                              @julianlambert17802
                              #456415
                              julian lambert
                                @julianlambert17802
                                #456419
                                Bob Stevenson
                                  @bobstevenson13909
                                  Could this be a Smart & Brown?…possibly an early/prototype 'Sabel'? The shape of the headstock and the cast base look very S&B and the stripped down pix look even more similar………I'm probably wrong but there DOES look like some kind of link.
                                  EDIT;…Take a look at page 2 of S&B 'L' model lathes on lathesUK here, many of the parts look similar…
                                  http://www.lathes.co.uk/smart-and-brown-model-L/page2.html
                                  Edited By Bob Stevenson on 10/03/2020 09:31:14
                                  #456429
                                  Lee Rogers
                                    @leerogers95060
                                    As suggested by previous posts Smart and Brown tool room lathe . Stedall is just the supplier . Very good machine , built like a tank and capable of very accurate work when in fine fettle.
