Hand files for aluminium
Home Forums General Questions Hand files for aluminium
Viewing 7 posts - 26 through 32 (of 32 total)
  • #365808
    Alan Jackson
      @alanjackson47790
      I have found that painting the file surface with white spirit helps to reduce the file clogging. I use a wire brush to clear most of the file grooves but I still have to pick out the stubborn bits with a pointed object.
      Alan
      Russell Eberhardt
        @russelleberhardt48058
        I find that French chalk a.k.a. talc helps. Cheapest source is Johnson's Baby Powder!
        Russell
        #365838
        Muzzer
          @muzzer
          These latex blocks are just brilliant for declogging belt sanders. I haven't tried it with a file but suspect it may be another effective way to clear teeth, particularly if combined with PTFE spray or WD40.
          Murray
          #365848
          Cornish Jack
            @cornishjack
            Muzzer – the last time I went to the MEX, (at least 10 years ago), the disc sander salesman was demonstrating that the standard super market plastic bag, rolled into a pad, does the same … and a bit cheaper!laughyes
            rgds
            Bill
            #365851
            Ian S C
              @iansc
              Or a bit of plastic garden hose. But a Dreadnought file is the way to go for fast removal of metal(tooth pattern (((((((, for finer work, ordinary files, new and kept for aluminium.
              I think Johnson's Baby Powder is starch based nowdays to get away from the ? cancer causing minerals in chalk.
              Ian S C
              Edited By Ian S C on 06/08/2018 12:24:21
              #365856
              Brian G
                @briang
                Chalk blocks and powdered chalk are still available from tack shops or dog groomers. (or even Amazon at a price)
                #366342
                Jon
                  @jon
                  Posted by Mark Rand on 05/08/2018 22:20:25:
                  Note:- Bastard files are between coarse files and second cut files. Bastard files are fairly rare these days. Coarse files are an endangered species.
                  Must admit you are quite correct, think it was the demise of the quality tooling over previous decades leaving a few producers calling them bastards when more like a courser second cut.
                  Last genuine bastards available in bulk must have been around 2002/3, there on after impossible to find a decent cutting file or one that lasts 1/4 as long pre 2002.
                  Dreadnought
                  Dreadnought
                  Millenicut
                  As above millenicut are straight teeth though can be angles like this.
                  Or like this Millenicut again.
                  Any file will scratch think about it, even a though proud over the whole file will scratch! They were only working with thin guage materials as well. You wont get even close to 10 thou with a millenicut yet alone file to sub thous!
                  Think that term millenicut used on aircraft is nonsense, most of the people didnt know how to use a file just learnt as they went on. In this case take a look at the last millenicut, will see the teeth are straight but angled- what that means is to mr average joe blogs is theyre pushing straight ahead right or wrong but the file effectively moves diagonally!
                  Now a tricked up filer can do that with any file just feeling for whats happening, cant teach that. Also this can and has been used to the filers advantage in clearing debris ie swing right to left in a scraping motion until starts to pick up, then opposite swing may or may not dislodge whilst also taking a cut.
