Posted by John McNamara on 27/12/2011 05:07:48:
Hi All
If a full size nut is used as a lock nut on top of a same size nut clamping a bolt or stud that uses the lower nut to clamp a member, the lower nut will most likely not be holding the load. the upper nut will press down on the lower nut disengaging the threads as the stud bolt or stretches, passing the load to the upper nut.
Not desirable as it increases the effective length of the fastening, allowing more spring.
If however a thin nut is used there will be less threads engaged in the thin nut. Provided the tolerances of both nuts are the same. the thin nut will expand more radially and be unable to disengage the lower nut (if it is properly tightened) from the bolt or stud; while firmly locking it in place.
Cheers
John McNamara.
Edited By John McNamara on 27/12/2011 05:10:53
Hi John, I’m sorry I can not agree with you. Firstly to achieve this you would have to tighten the lock-nut up to a greater torque than the load-nut, and secondly you would not do this, and further more in my life time of using nuts and bolts most every day in industry and the many hundreds of times I’ve used two nuts of the same thickness and rating, I have never experienced this situation.
It is worth reading Tubal Cains artical “Bolts, Nuts and Screws” in ME vol 140 issue 3500 pages 1069-1073.
Regards Nick.
Edited By Nicholas Farr on 27/12/2011 11:10:18
