My experience with bandsaw blades took a leap up when i got involved in building a saw that was designed to cut the runner and riser pipes that come from the sea bed up to a drilling rig.
When a well is finished the big valve on the sea bed is closed and the pipes were blown off about 70 feet below the surface as the rigs can only lift 70 foot of string at a time.
However new regs introduced say all pipe has to be removed so then send an expanding tool down like a 3 fingered hone which grinds away as it opens up and severs the pipe just above the valve, quicker that submersibles trying to undo the flange. They then lift this pipe up to max hight and clamp it there.
two machines go into action, a big bandsaw that cut the top 70 foot off to go into a supply boat and below this a double ended core drill that belts a 4″ hole thru from both sides for a pin to go in for the next lift.
This drill pile can be different sizes but usually the outer is 32″ diameter and about 1″thick, inside this is a 24″ pipe about 1 1/4″ thick and inside this is an 18″ pipe same thickness.
Between the two outer tubes they are filed with cement, not concrete and also in the pipe are butterfly clamps that are spring loaded to keep the pipes concentric whist the cement is poured.
For some reason these are hardened ?? and no one knows where they are when you are cutting.
The saw in question was fabricated out of 6″ square stainless tube with a 1/2″ wall thickness, plenty of gussets etc and carried a 2″ wide blade 1 tpi, tipped and was powered by a 10 HP hydraulic motor [ no electric motors allowed on deck ]
We had a section of pipe specially made for us 8 feet long with 30 butterfly clamps fitted and marked, every test cut had to be thru a clamp. When we started off blade life was in minutes and we got Lennox out to assist.
first question they asked was how tight were we tightening the blade and the answer was we didn’t know but we thought we were not over tightening it. They put their gauges on the blade and got us to tighten it up, gauges never moved.
We kept tightening and it still never moved and we ran out of adjustment.
All we were doing was bending the frame.! !
Back to the drawing board and the frame was stiffened up with side plates of stainless 6″ x 1 1/2″ this time we got a reading but it was far, far more than I would have tightened up, thing 3/4″ drive socket with 5 foot of bar on it !!
Lennox were magnificent on this and first cuts were 1 hour 20 minutes and with a bit of tuning we got it down to just over the hour.
They came back with a 1 1/2″ wide blade, vari tooth with tips on it the size of match heads. I laughed when I saw it and told the guy no was, on the blade we had we were loosing 10 or so tips per cut and one blade did 4 cuts and was scrap.
So we ran it, not our blade anyway and lost 2-3 teeth per cut, 7 to 8 cuts before it was scrap and cutting time down to 45 minutes.
They gave all the lad on the job a hacksaw and a load of blades, one lad didn’t want his so I got two.
I asked about releasing tension and the Lennox guy just smiled and said if you have to release tension something isn’t right.
Modern version of the original but not for runner and risers pipes.
John S.
