Guiness world record?
Home Forums The Tea Room Guiness world record?
Viewing 25 posts - 1 through 25 (of 25 total)
  • #527738
    pgk pgk
      @pgkpgk17461
      I tooka small item into shed to put in a battery. 2 tiny screws removed with jewellers screwdriver… and yes, I dropped them!
      Then bent down and picked both up from the floor!!!
      pgk pgk
        @pgkpgk17461
        anyone beat this?
        #527740
        Jeff Dayman
          @jeffdayman43397
          I'd give Guinness WR a call! That would not have happened that way in my shop these days – they'd be gone like the wind. smiley
          #527802
          mechman48
            @mechman48
            I don't even bother looking; just wait until I do a weekly clean up then sift through the debris ..dont know … If I'm lucky !
            George.
            #527803
            old mart
              @oldmart
              You must have cheated and swept the floor first.smile o
              #527804
              Dominic Bramley
                @dominicbramley60728
                Without Norris there to verify the attempt, I'm afraid no-one is going to believe you!
                Dom
                #527807
                Samsaranda
                  @samsaranda
                  Having worked on aircraft, when you drop a screw or a bolt you develop a sixth sense that is able to track where it’s gone, very embarrassing if you can’t find the missing item in the aircraft structure. Loose nuts bolts and screws have a habit of finding areas like controls where they can jam items, definitely not desirable if it’s flying controls etc. Dave W
                  #527809
                  Grindstone Cowboy
                    @grindstonecowboy
                    Dedication's what you need!
                    (Only those of a certain age will understand the full significance of this wink)
                    Rob
                    P.S. if you haven't got dedication, a magnet in a plastic bag is a reasonable substitute for finding ferrous fasteners
                    #527837
                    Shadow
                      @shadow
                      Great respect for your accomplishment! I have searched for small screws in office carpet.
                      Literally almost down the drain. My most miraculous save was when servicing an obsolete microscope at a medical clinic on their countertop. I was reinstalling a 1mm slotted set screw when I dropped it and I heard it hit in the stainless steel sink about 18" away. I picked it out and the same thing happened but an immediate search found nothing. A second search found it in the small ring of water surrounding the drain, disaster averted.
                      #527855
                      Vic
                        @vic
                        Posted by pgk pgk on 16/02/2021 14:14:09:
                        I find this extremely unlikely, not impossible but unlikely … laugh
                        #527869
                        Phil super7
                          @philsuper7
                          I think it all depends if the workshop pixies are watching at the time.
                          #527874
                          pgk pgk
                            @pgkpgk17461
                            I swear it's true, Gov.
                            As they slipped out of the part i'd stupidly turned upside down I said "Oh, Gosh this could be a bit of a pickle" (or words to that effect) followed by "well, bless me, there they are side by side at my feet in a crater of dust"
                            ..which considering I couldn't find the mole- grips earlier…
                            pgk
                            #527889
                            Windy
                              @windy30762
                              Bits I drop seem to have a spring on them and land where you don't expect them to.
                              #527891
                              Dominic Bramley
                                Last week I was knocking the pin out of a knurling wheel and thought to myself "this is going to fall on the floor and get lost". I had 3 second look around for something to catch it in before thinking "**** it – I'll just watch where it lands".
                                Bang! Gone.
                                Dom
                                #527895
                                Nigel Graham 2
                                  @nigelgraham2
                                  My workshop pixies amuse themselves even without my aid. A couple of times lately they have knocked objects some distance from me onto the floor.
                                  I used a set of ball-ended Allen keys in dismantling my old drawing-board the other day. That was in the house. The keys, in their plastic block, normally live on a shelf in the workshop.
                                  Wanted them today, in the workshop. Gorn! So has the big tobacco-tin stuffed with assorted Allen keys.
                                  Luckily I found a key that fitted the M6 cap-screws I was using – note I didn't say a key for M6 cap-screws. Just one that managed the task in hand.
                                  I don't need drop tiny objects on the shed floor to lose them – I can lose quite sizeable things without any trouble at all!
                                  #528028
                                  mechman48
                                    @mechman48
                                    How many have done simlar as in putting some thing down on the bench/worktop, turned away to get something else, turn back & cannot find the item you put down, no matter how hard you search. You then go & get an alternative tool to do the job intended put that down on the bench… right next to the item you lost in the first place, I did that yesterday. Those workshop gremlins are pretty smart, & damned fast too !
                                    George.
                                    #528040
                                    Dalboy
                                      @dalboy
                                      Posted by mechman48 on 17/02/2021 13:35:20:
                                      George.
                                      I can relate to that lost count how many times I have done that, then decide to clean the bench to stop it happening again only to loose the next pieceblush
                                      #528080
                                      Howard Lewis
                                        @howardlewis46836
                                        SOMEWHERE under the bench are a load of high number drills, dropped the box, half fell out and vanished heaven only knows where. Probably guarded by all the small BA nut ans washers that have escaped my grasp.
                                        How long can it take to find a M6 x 100 bolt after falling about 300 mm onto a steel bench? About 30 minutes in my shop. How did it get to hide behind the Mill? But I got it!!!!
                                        Have just spent half a day resetting this PC after it decided to rest the outgoing mail server details, without my permission or aid. Having FINALLY got it reset, it is obviously sorry and now recompences me by working faster than ever before.
                                        #528119
                                        peter smith 5
                                          @petersmith5
                                          You mean that you can actually bend down???
                                          I have to get “ Erin doors” to put me socks on of a morning.
                                          pete
                                          #528124
                                          pgk pgk
                                            @pgkpgk17461
                                            Posted by peter smith 5 on 17/02/2021 18:26:45:
                                            pete
                                            Lie on my back on the bed and bend knees to put on socks
                                            Squatting down not so bad – so long as have something to pull myself back up. Worst is gardening – usually means crawling…
                                            I do try an do excercises to keep bits working. Rowing machine temporarily abandoned after spraining an ankle – 6 weeks ago and still painful and swollen. But one arm dumbell lifts and presses and pec excercises. If I miss 2-3 days then weight capability drops markedly….
                                            I also practice putting shorts on standing on one leg- balance is becoming an issue but it helps to have the lifted leg swung slightly across the standing leg…
                                            pgk
                                            #528128
                                            peter smith 5
                                              @petersmith5
                                              You need to take more water with it!
                                              pete
                                              #528341
                                              Anthony Knights
                                                @anthonyknights16741
                                                Hello Mr Pete Smith. What you need is one of these;-
                                                My daughter bought me one, now I'm unfortunately on my own. I couldn't manage without it.
                                                Regards Anthony
                                                #528360
                                                peter smith 5
                                                  @petersmith5
                                                  Looks good but will it do up me laces??
                                                  pete
                                                  #528366
                                                  Mike Poole
                                                    @mikepoole82104
                                                    I used to be able to get my foot behind my head but just checked and big toe is about 7” from my nose. I suppose losing 4 stone and actually doing some exercise might improve that. I expect leg muscles will now complain tomorrow sad
                                                    #528377
                                                    Anthony Knights
                                                      Velcro is easier than laces.
