Gluing metal
Gluing metal
Home Forums General Questions Gluing metal
  • #485663
    coggy
      @coggy
      Does anyone know of an adhesive that will do this job, please?
      I want to stick/glue a piece of mild steel about 4mm wide to a piece of hardened steel about 8mm wide. It needs to survive being outdoors but not during winter, so it shouldn't freeze. It will be getting wet and there is not much mechanical force trying to separate the pieces, say no more than you can push with your finger. It is a permanent fix and the glue needs to be concealed between the pieces.
      Thanks.
      Edited By coggy on 14/07/2020 21:32:45
      coggy
        @coggy
        #485672
        mechman48
          @mechman48
          Try two part epoxy resin; key both surfaces first.
          George.
          #485675
          Martin Kyte
            @martinkyte99762
            Silicone sealent ?
            regards Martin
            #485678
            Enough!
              @enough
              Agree with George.
              Clean the pieces with alcohol before bonding. Then clean them again.
              Mix the two parts of the epoxy. Then mix them again.
              Edited By Bandersnatch on 14/07/2020 22:44:41
              #485692
              Maurice Cox 1
                @mauricecox1
                You might consider “J.B. Weld. I used this on a job, and placed the parts incorrectly. When this has happened with “Arraldite”, a smart tap with a hammer has broken the bond, ready for a retry. Not with J.B. Weld. All that hitting it with a hammer did was to dent the surface. I had to heat it up with a torch to get it apart!
                Maurice
                #485698
                Plasma
                  @plasma
                  Plus 1 for JB Weld.
                  I use it for model making too, creating authentic looking castings from fabricated parts with it.
                  There are two types, standard which takes a long time to set up and rapid which just takes a few minutes.
                  It contains steel filings so gluing magnets can be difficult.
                  Scrupulous cleaning is a must like any gluing, soldering operation.
                  Mick
                  #485700
                  Kiwi Bloke
                    @kiwibloke62605
                    Loctite 380 Black Max. Given scrupulous cleansing before use, it's much better than 'standard' cyanoacrylates, being rubber-toughened. A 'must' for the toolbox!
                    #485715
                    Dalboy
                      @dalboy
                      As above 2 part epoxy glue abrade and clean the mating surfaces
                      #485721
                      Robert Atkinson 2
                        @robertatkinson2
                        4mm wide, but how long snd how thick? What is the bond area? That said a metal filled epoxy like JB weld, Araldite Steel is likely to be the best choice if you want a hidden bond as the glue line or fillet will look like steel. but from your described requirements any epoxy or super glue would work. For structural meatal bond toughned acrylic like Loctte 330 or Permabond TA435 are a good option.
                        Robert G8RPI
                        #485780
                        coggy
                          @coggy
                          Thanks all, that gives me some ideas to look at.
                          #485787
                          John Haine
                            @johnhaine32865
                            Gorilla glue clear may also work.
                            #485797
                            Martin Hamilton 1
                              @martinhamilton1
                              That's a no brainer, JB Weld original. Incredible what this stuff will do, you can even drill & tap threads in it. It also takes more heat to break a bond than just about any other 2 part adhesive.
