If it needs to be said, each Involute gear cutter only covers a range of tooth numbers, so that to cover from 12 to a rack, you would need eight cutters. With Brown and Sharpe type DP cutters a No.1 will cut from 135T to a rack, while a No.8 will cut 12T and 13T. So if you only want a 127T, you need a No.2.
Each cutter should be marked with the depth of cut, as "D+f", as well as the number and tooth range.
Workshop Practice Series No 17, "Gears and Gear Cutting" by Ivan Law will provide a lot of information on gears and cutting them in the home workshop.
My practice, following Ivan Law's advice, is to cut each tooth space in one pass, with a very light feed. My view is that multiple passes could introduce error from cut to cut.
I am NOT expert in gear cutting!
