Jason
When you machine the tapers you remove a lot of metal and it releases tensions on the end of the shaft. The reason they where straitened twice was to ensure the tapers run true to the shaft.
And yes they were that delicate due to there weight we used special lifting spreader bars and delivery jigs.
The patrol boat shafts had to be inserted into the boats by Navy approved fitters.
Now have you ever been on a large ship and felt a distinct thump while under way.
There can be two reasons for that: The shaft is bent or the propeller has not been scraped in properly.
When the prop is scrapped it is fitted to the shaft in a special jig and rotated to check that each blade tip tracks on the same radius. The pitch is measured in roughly for sections of each blade.
It is then balanced and all the exposed shaft not in the bearings were wrapped in fibre glass matting and sprayed with resin and hardener.
The shafts were rated for 900 revs. The diesels reved out to about 1500 rpm with gear reduction to the shaft.
The biggest ship I fitted was 25,000 ton and the prop was 12 ton.
The patrol boats were 2000 ton.
Larry
